Need a French and German translation of short document
I'd appreciate if someone translated this into French. Thank you.
Quote:Quick Start Guide [EN]
Congratulations on receiving your PineTab Early Adopters Edition! You are one of the very first to receive the PineTab - we therefore hope you’ll actively engage with developers and other community members. You have the chance to set the pace of software development by actively contributing to the process. There are multiple ways for you to engage with us including our forums, IRC, Discord, Matrix and Telegram, all of which are accessible from pine64.org.
1. Getting Started
Our community maintains a well documented Wiki at wiki.pine64.org. The PineTab Wiki subsection is just getting built-up, but once it is complete it will include information about troubleshooting, available operating systems (OSes), hardware disassembly, adapter board installation, the PCB layout as well as many other aspects of your device. Make sure to consult it regularly and contribute to it in any way you see fit. Anyone with a PINE64 forum account (forum.pine64.org) can contribute to the Wiki.
2. Operating System
This PineTab ships with the Ubuntu Touch operating system. Ubuntu Touch is developed and maintained by UBports Foundation and is therefore different in form, function and application compatibility to other Ubuntu Linux flavours. As the name entails, Ubuntu Touch is built with touch input in mind, but it converges to a more standard desktop when a keyboard and trackpad are attached. Ubuntu Touch is hence a perfect fit for the PineTab.
The PineTab ships with the latest Linux kernel and open source drivers. This extends to the open-source Lima GPU driver, which accelerates the Lomiri (formerly Unity8) shell. This Ubuntu Touch build has support for most hardware features of the PineTab, but it is still a work-in-progress and so you should expect bugs (which we’d appreciate if you reported).
We suggest that you do not plug in the PineTab keyboard on the first boot. To use the keyboard, once the initial setup is complete, turn the device off and attach the keyboard; boot with the keyboard attached. From this point on you’ll be able to connect and disconnect the keyboard and switch between the touch-input UI and desktop UI.
3. Cautions
The PineTab Early Adopters Edition is aimed at hackers and tinkerers willing to contribute to the development process.  We expect and even encourage you to experiment with the software and hardware by pushing the envelope. That said, please keep in mind that the device is under standard warranty, so breaking components during disassembly or tampering with eFUSEs is a subject to voiding your warranty. We trust this is common sense.
4. Support
You are welcome to share your experience and ask any questions you may have on our forums and in the PINE64 community chats, all of which are accessible via the Forums and Chats drop-down on our main page (pine64.org). We have also prepared a page of information to help you get started with your PineTab at wiki.pine64.org/PineTab/Early-Adopter.
For all non-software related questions please email: support@pine64.org
Have fun!
Here is my French translation:
Quote:Guide de démarrage rapide [FR]
Félicitations pour la réception de votre PineTab édition Early Adopters (Pionnier) ! Vous êtes l'un des premiers à recevoir une PineTab - nous espérons donc que vous rejoindrez nos membres et nos développeurs pour prendre part activement à la communauté. Vous avez l'opportunité d'accélérer le développement logiciel en prenant part au processus. Il y a de multiples moyens à votre disposition pour vous permettre de participer : nos forums, IRC, Discord, Matrix et Telegram; tous sont accessibles depuis le site pine64.org.
1. Première utilisation
Notre communauté tient à jour un Wiki bien documenté sur wiki.pine64.org. La section PineTab du Wiki est en court de construction, mais une fois terminée elle contiendra des informations sur la résolution des problèmes, la compatibilité des systèmes d'exploitation (OS), le désassemblage de la tablette, l'installation des différents adaptateurs, les schémas des circuits imprimés (PCB) ainsi que bien d'autres aspects de votre appareil. N'hésitez pas à le consulter régulièrement et à y apporter votre contribution si vous le souhaitez. Il vous suffit pour cela de posséder un compte utilisateur sur le forum PINE64 (forum.pine64.org).
2. Système d'exploitation
La PineTab que vous avez reçue utilise le système d'exploitation Ubuntu Touch. Ubuntu Touch est développé et maintenu par la fondation UBports et est par conséquent diffèrent d'autres versions d'Ubuntu Linux en termes d'apparence, de fonctionnement ainsi que de compatibilité des applications. Comme son nom l'indique, Ubuntu Touch est conçu pour les interfaces tactiles, mais il peut également fonctionner avec un clavier et une souris. C'est ce qui fait d'Ubuntu Touch le système d'exploitation idéal pour la PineTab.
La PineTab est expédiée avec les dernières versions du noyau Linux ainsi que des pilotes open-source. Cela inclut le pilote open-source du GPU Lima, qui accélère l'interface Lomiri (anciennement Unity8). Cette version d'Ubuntu Touch supporte la plupart des fonctionnalités de la PineTab, mais étant toujours activement en développement il est possible que vous rencontriez des bugs (et nous apprécierions que vous nous les rapportiez).
Nous vous conseillons de ne pas connecter le clavier PineTab lors du premier démarrage. Pour l'utiliser une fois la configuration initiale terminée, éteignez l'appareil, connectez le clavier, puis démarrez la tablette. Vous devriez ensuite pouvoir connecter et déconnecter le clavier et ainsi basculer entre l'interface tactile et l'interface classique (desktop).
3. Mise en garde
La PineTab édition Early Adopters a été conçue pour les hackers et les makers qui souhaitent prendre part au processus de développement. Nous espérons et nous vous encourageons même à expérimenter avec le logiciel et le matériel "sans restrictions". Cela dit, merci de garder à l'esprit que cet appareil dispose d'une garantie standard et que par conséquent les composants endommagés lors du désassemblage ou toute modification des fusibles électroniques (eFUSEs) annuleront cette garantie. Il s'agit, selon nous, de bon sens.
4. Support technique
Votre expérience ainsi que toutes questions sont les bienvenues sur nos forums ainsi que dans nos salons de discussion dédiés à la communauté, qui sont disponibles via le menu déroulant 'Forums and Chats' sur notre site (pine64.org). Nous mettons également a votre disposition une page d'information pour vous aider à utiliser votre PineTab à l'adresse suivante : wiki.pine64.org/PineTab/Early-Adopter.
Pour toute question qui ne concerne pas un problème logiciel, merci de nous envoyer un courriel à : support@pine64.org
Amusez-vous bien!
Let me know if you want to change something or if you have something else to translate in French  Smile
You only need the French translation? Because a German translation is mentioned in the title
Got all translations now - thank you!
