Here's a slightly improved pineaudio program. It's based on one of the older releases that I know to be good.
This is useful if you're trying to run a desktop oriented GUI/distro but need call audio to work, like me.
Generally, you have to run pineaudio twice to get call audio working. Once without a '2', and the second time with a 2.
This version fixes that so you only need to run the '2', and it increases the default volume, as well as offers a way to easily increase volume further.
Add a '+' to double the volume for all enabled components. Previous versions would set the speakerphone to a low volume which was a problem for me and a pain to manually readjust.
So, e.g. ./pineaudio -sm2+ enables call audio speakerphone with a high volume.
It's a tiny fix, but its absence is annoying enough I figured I'd post it here.
