Hi
I would like to connect my usb keyboard and mouse to my pine 2gb using usb hub I am currently using Remix OS 2.0 .
When i connect directly the usb keyboard and mouse to pine it works absolutely fine.
But problem as pine have only two usb port when i have connected usb keyboard and mouse i would also like to connect my external hdd and usb pendrive.
so i tried to use 4 port usb hub but it was not able detect or not working the usb keyborad and mouse
I like to knew its this problem with Remix OS or o/p usb power is not sufficient to use hub.
 ) I left purposely GND connected because I suppose it is balance also for D- and D+ and act as a shield.
