USB-C CC pins are pulled to the GND by AW3512 (VCONN switches) when VCONN is off
#41
I desoldered the switches. However, USB devices are still not recognized. I tried a USB keyboard and USB smartcard reader, connected directly and connected through a powered hub. The devices don’t show up when running lsusb on SXMO / PostmarketOS. Furthermore, the status LED of the smartcard reader does not turn on. So there is no power. Charging the phone fortunately still works. My PinePhone is from an early batch, got it from a friend.
Any idea what I can do?
It would be nice if I can get the smartcard reader to work. Other devices are not that important.
My shoddy soldering job:
Got it to work! Although, lsusb still reports nothing, I can now use the powered hub, the smartcard reader (with gpg), and the USB keyboard.
Steps under PostmarketOS / SXMO:
  1. Flashed the ANX firmware using method 1.
  2. Just to make sure everything is properly reinitialized, I shut down the phone, took out the battery, put it back in, and started the phone again.
  Kill switches for Wifi/Bluetooth does not work luxgiammi 0 3,169 10-14-2024, 03:34 PM
Last Post: luxgiammi
  pine64 keyboard pogo 'no-go' pins --- 3 6,384 04-29-2022, 04:59 AM
Last Post: Humid Stylus
  PP v1.2 VCONN question m4xx3d0ut 0 2,323 03-18-2022, 12:26 PM
Last Post: m4xx3d0ut
  what are these pins above modem chip? zetabeta 1 3,838 12-13-2021, 04:38 AM
Last Post: kqlnut
  Pogo pins power clarification - reading schematics bokomaru 48 97,689 06-19-2021, 10:46 AM
Last Post: bokomaru
  Is the PinePhone only Pine-device with hardware switches? harrm 1 4,623 01-23-2021, 12:29 AM
  Where are the HW kill switches located? WaldoTheRanger 11 26,026 10-04-2020, 02:23 AM
Last Post: WaldoTheRanger
  Only enable modem when needed with kill switches sokolgeo 2 8,373 09-20-2020, 04:40 AM
Last Post: sokolgeo
  hardware switch wishlist/discussion - switches on the outside? mypine 7 13,036 04-12-2020, 10:40 AM
Last Post: wibble
  Kill switches blicken 2 6,679 02-08-2020, 03:51 PM
Last Post: wibble
