Article: Connect PineCone BL602 to LoRa Transceiver
Here's how we transmit LoRa packets over the airwaves with PineCone BL602...
Hi lupyuen! Thanks for the article Smile
Thanks for reading
@lupyuen Thanks for another great article!
I am guiltily still waiting to find a time to actually hack on my PineCone Sad I intend to use your book to get started. The plan is to potentially use it as a controller for high-speed mass storage: https://forum.pine64.org/showthread.php?tid=13301
I came across this just the other day, it may be of interest: http://web.cs.ucla.edu/~omid/Papers/Hotnets19.pdf It's basically BLE rolled into WiFi, it could be interesting to investigate on the PineCone.
Thanks! That's a really interesting use case. I'll probably be stuck on LoRa for a while because to make it really useful, I need to support LoRaWAN and The Things Network.
I am curious if there is a parts list available (so I can buy the same parts). In particular I am curious about the selection of antenna.
(03-27-2021, 02:18 PM)bikerlatt1 Wrote: I am curious if there is a parts list available (so I can buy the same parts). In particular I am curious about the selection of Kodi nox antenna.
RAKwireless WisBlock talks LoRa with PineCone BL602 RISC-V Board
@lupyuen I am becoming more and more curious about these LoRa networks, I read they are pretty cool. I have some questions if you don't mind?
1. What is the expected range in a built-up urban location? I see people quote 10km, but what could you realistically expect to see?
2. Are there some rules around how much you can use the communication? Are you expected to give way for example to allow other people to communicate?
3. If it is a mesh, do you select a target node in the network and rely on other people to relay your message?
4. Can the mesh be connected to the internet to further its range, or is it intentionally left off of the internet? For example, LoRa -> LoRa -> Internet -> LoRa - meaning you could communicate well outside the range of your mesh network?
5. Again if it's a mesh, what kind of routing protocols are being used? Is there some limitation of how many devices can be in close proximity?
6. Is there some unique ID for each device?
7. Is encryption allowed on the network, or must the traffic be unencrypted? At the very least I hope that signatures are allowed?
Any answers would be great to hear Smile
  Article: LoRaWAN on PineDio Stack BL604 RISC-V Board lupyuen 0 35 09-15-2021, 09:27 PM
Last Post: lupyuen
  Article: BL602 Bootloader lupyuen 2 412 09-09-2021, 11:35 AM
Last Post: lupyuen
  Article: Rust on RISC-V BL602: Rhai Scripting lupyuen 0 94 09-04-2021, 12:08 AM
Last Post: lupyuen
  Article: PineDio Stack BL604 RISC-V Board: Testing The Prototype lupyuen 2 164 08-29-2021, 10:19 AM
Last Post: lupyuen
  Article: Rust on RISC-V BL602: Simulated with WebAssembly lupyuen 0 141 08-15-2021, 07:13 PM
Last Post: lupyuen
  Article: Rust on RISC-V BL602: Is It Sunny? lupyuen 0 239 08-02-2021, 06:17 PM
Last Post: lupyuen
  Firmware BL602 on magic home controller daubsi 0 293 07-10-2021, 05:16 AM
Last Post: daubsi
  Article: Reverse Engineering WiFi on RISC-V BL602 lupyuen 4 1,041 07-08-2021, 09:20 PM
Last Post: lupyuen
  Article: Machine Learning on RISC-V BL602 with TensorFlow Lite lupyuen 0 355 06-21-2021, 06:52 AM
Last Post: lupyuen
  Article: Simulate PineCone BL602 with WebAssembly, uLisp and Blockly lupyuen 0 380 05-27-2021, 07:37 AM
Last Post: lupyuen
