I messed up my spi and found solutions on bypassing the spi but it doesn't seem to work. I flashed the pinebook pro spi image by accident. On the rockpro64 wiki, it states you could jump pins 23-25. It doesn't appear to do anything. The white light does not appear. I currently am trying to boot from emmc which should be default boot unless that has changed...
Any help would be appreciated.
02-01-2021, 04:07 AM
(This post was last modified: 02-01-2021, 04:09 AM by dukla2000.)
Yup, I have yet to find a "current" release (with a 5.x kernel) that supports the RockPro64 eMMC. Stick to an SDcard while trying to recover and remove the eMMC.
Pretty sure you will still need to jumper/disable the SPI.
- PinePhone BraveHeart now v1.2b 3/32Gb daily driver, Tow-boot with pmOS/SXMO on eMMC
- PinePhone pmOS Community Edition 2/16Gb driving my picture frame, Tow-boot with pmOS/SXMO on eMMC
- PinePhone Pro Explorer Edition, Tow-boot on SPI, Arch/SXMO on eMMC
- ROCKPro64 v2.1 2GB, 16Gb eMMC retired in favour of a fruity upgrade
02-01-2021, 02:42 PM
(This post was last modified: 02-01-2021, 02:43 PM by dukla2000.)
I thought in the Ayufan scripts there was an option to reactivate SPI from Linux: a lot of his RockPro64 stuff is under his Rock64 names/directories. I am not in front of my RockPro today but there are a whole bunch of his scripts under /usr/ somewhere - could be worth having one of his (4.4 kernel) releases on your SDcard.
ps - I have never had a serial cable for a console.
