Hooks and userscripts: POST 'EM!
Hook-seller! I need your STRONGEST hooks and userscripts!
I'll start.
Surf gesture so that back and enter go back and forward in history.
#!/bin/sh # $HOME/.config/sxmo/hooks/gesture case $1 in         "surf")                 if [ $2 = "back" ]; then                         xdotool key ctrl+h & exit 0                 elif [ $2 = "enter" ]; then                         xdotool key ctrl+l & exit 0                 else                         exit 1                 fi                 ;;         *) exit 1 esac
Ring hook that checks if the number is a contact. If so, it will ring, if not, it won't! This cuts down on being annoyed by robo-callers. It also checks if the file $HOME/.config/sxmo/silent exists. If so, it won't ring. I stole the main bits of the ring/pickup scripts from someone here (if it's you, sound off and thanks!) but added the contact/silent checking.
#!/usr/bin/env sh # $HOME/.config/sxmo/hooks/ring NUMBER="$1" CONTACT=$(sxmo_contacts.sh --all |         grep "$NUMBER" ) SILENT=$HOME/.config/sxmo/silent incallmonitor() {         CALLRINGING=$(mmcli -m "$(modem_n)" --voice-list-calls)         echo $CALLRINGING                 if [[ "$CALLRINGING" == "No calls were found" ]]; then                     exit 1         fi } modem_n() {         MODEMS="$(mmcli -L)"         echo "$MODEMS" | grep -qoE 'Modem\/([0-9]+)' || finish "Couldn't find modem - is your modem enabled?"         echo "$MODEMS" | grep -oE 'Modem\/([0-9]+)' | cut -d'/' -f2 } if [ -n "$CONTACT" ]; then         sxmo_audioout.sh Speaker         amixer sset 'Line Out' 100%         if [ ! -f $SILENT ]; then                 mpv --no-resume-playback /home/mo/Music/char.opus         fi         while true; do                 sxmo_vibratepine 1000                 notify-send $1                 incallmonitor "$1"         done else         while true; do                 notify-send $1                 incallmonitor "$1"         done fi
#!/bin/sh # $HOME/.config/sxmo/hooks/pickup ID=$(ps -ef|grep ring|grep -v grep|perl -ne '$_=~ m/^ *(.*) mo.*/;print $1') kill -9 $ID pkill mpv sxmo_audioout.sh
#!/usr/bin/env sh # $HOME/.config/sxmo/userscripts/silent SILENT=$HOME/.config/sxmo/silent if [ -e $SILENT ]; then         rm $SILENT && notify-send "Not Silent" else         touch $SILENT && notify-send "Silent" fi
I'm not the greatest shell scripter, but with just a little bit here and there, sxmo gets comfier and comfier. It is now "legs go numb on the toilet while looking at memes on the pinephone" worthy. I'm also looking for some apps hook examples if you got 'em! I can't seem to make mine work without breaking something.
Tongue how to manage userscripts Uturn 7 10,171 08-01-2022, 02:33 PM
Last Post: TRS-80
