Trisquel Mini
I want to to use the H64 B as a desktop...surfing the web and e-mail, etc.
I want to try Trisquel Mini ( 1.2 GB)  with at least 64 GB eMMC. I "Think" it should work as Ubutu supposedly works, and Trisquel is the more secure version of Ubuntu...
Any advice?
Thanks!
@Basic Unfortunately, as far as I know, trisquel only offers builds for x86/amd64 on their website and does not support ARM64 at the moment.
If you want to run your desktop without blobs (which is why I suppose you want to use Trisquel) I recommend using Debian instead. See these threads:
- https://forum.pine64.org/showthread.php?tid=10645
- https://forum.pine64.org/showthread.php?tid=11703
However, please be warned that the built-in wifi does not work without blobs at the moment. Also, the support status of the ethernet is rather unclear. Last but not least, Debian is more universal than Ubuntu/Trisquel and does not ship a "nicely preconfigured" desktop. However, you can install LXDE or LXQt yourself and make a few changes to it which will result in something close to Trisquel.
(01-11-2021, 12:35 PM)kuleszdl Wrote: @Basic Unfortunately, as far as I know, trisquel only offers builds for x86/amd64 on their website and does not support ARM64 at the moment.
Thank you for the information.
I have a lot to study in your reply, that is why I chose the name "basic". Big Grin
Do you ( or any one else) have an opinion on Majaro KDE Plasma made for the Rock Pro?
( I presume the differences are minimal?)
I would rather say the difference is rather big. In the end, it's the difference between using a rolling distro or a "frozen" one like Debian/Ubuntu. Personally, I prefer the latter as I like to have a system that - once I got it working - keeps working and does not occasionally break after updates. If you are more on the edgy side and want to have the newest stuff, a rolling distro might be the better option. Also, when running on not-so-well-supported hardware (like the PINE-H64) hardware support might be a lot better.
Yet, I think that it's pretty feasible to run the H6 with the combination of Debian stable and an unstable kernel (eventually using a usb-ethernet-adapter if the driver makes trouble). The upcoming Debian 11 version (bullseye) should have better support for the H6, although I doubt it will officially support it ootb.
(01-14-2021, 04:01 PM)kuleszdl Wrote: I would rather say the difference is rather big. In the end, it's the difference between using a rolling distro or a "frozen" one like Debian/Ubuntu. Personally, I prefer the latter as I like to have a system that - once I got it working - keeps working and does not occasionally break after updates. If you are more on the edgy side and want to have the newest stuff, a rolling distro might be the better option. Also, when running on not-so-well-supported hardware (like the PINE-H64) hardware support might be a lot better.
Again thank you for the info.
I had issues with Ubuntu, especially when they added the "null" session ( geust user) years ago. I just "fixed" 2 laptops belonging to my wife and daughter operating on windows, my daughter's required a new hard drive and Trisquel. As much as it was a pain, it is nice to see her use Linux.
I am leary about Debian due to it's origins, that is all I can say on the matter.
I looked up the differences ( h64/ Rock pro) and indeed you are correct.
I suppose if I go the H64 route, I would have to wait for the Manjaro community to provide a specific immage for it's startup requirements and system requirements.
proper Manjaro support would be nice as it supports many other PINE devices fairly well.
it doesn't get happy
it doesn't get sad
it just runs programs
(02-18-2021, 10:08 PM)zer0sig Wrote: proper Manjaro support would be nice as it supports many other PINE devices fairly well.
Yes it would. I have used it on some other non-pine64 devices, after one failed update that scrambled the OS, I managed to get a working updated image, and was impressed.
