Display options for the Rock64
So I just received my Rock64 through Amazon with the 16x2 LCD, 5v 3a power adapter and 16gb sd card bundle a few days ago. I have to say, I'm very impressed with it so far. Currently, I'm just focusing on making it into an emulation system rather than a mini desktop. It's the 1GB version, but for my projects I really don't need anything more powerful.
So, I'm looking for small display options for the Rock64 and currently all I'm finding are the ones that hook up to the HDMI port. I do plan on making the rock64 into a portable emulating gaming console sometime in the future. The raspberry pi displays don't obviously work, as those have a ribbon cable, with the Rock64 does not have.
My question is are there any displays that can be hooked up to the PI-2 bus, so the HDMI port can be used for another larger external display if needed? If not, then I'll have to use a small display that connects to the HDMI port on the rock64 such as THIS.
Thanks in advance.
Also, I've noticed that the Rock64 and the Raspberry Pi have the same GPIO layout. Except the Raspberry pi calls pin #19 GPIO 10, pin #21 GPIO 9 and pin #23 GPIO 11. Where as the Rock64's pin #19 is GPIO3_A1, pin #21 GPIO_A2 and pin #23 GPIO3_A0.
Could a display such as the one linked below work with the rock64's pi-2 GPIO bus? I could care less about the touch screen capabilities. As long as the screen works as intended I'm a happy camper.
https://www.amazon.com/dp/B07L9XM11M
User documentation for the display pinout can be found at the link below on page 2, in the PDF named 5inch_HDMI_Display_User_Manual.
https://mega.nz/folder/rIEH1J4Z#gEExHaWL...r/qQVi3LZZ
  DeskPi case alternative for ROCK64 v1k699 2 13,238 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,566 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,498 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 48,622 03-24-2025, 06:35 PM
Last Post: arunkhan
  Looking for a good display for my RockPro64 RK3399 ziomario 0 2,142 11-09-2024, 10:13 AM
Last Post: ziomario
  Are HW design files available for ROCK64? irenek 3 11,310 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 4,937 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 21,642 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 6,583 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 8,973 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
