How to setup a ffmpeg streaming server on Manjaro?
On my PinebookPro running Majaro, I try to setup a ffmpeg streaming server.
I start ffmpeg this way:
ffmpeg -listen 1 -i rtmp://localhost:1935/live/cube -c copy  rtmp://localhost:1935/live/mpv
As a result, ffmpeg is hangig as if it was listening on the socket. But when I check the sockets (e.g. with ss -a), port 1935 is not displayed.
When I try to stream from the pinecube, with this command:
[root@nixos:/home/nixos]# ffmpeg -s 640x480 -r 15 -i /dev/video0 -vcodec flv -f flv rtmp://pbp:1935/live/cube
 I get this error:
[tcp @ 0x81110] Connection to tcp://pbp:1935 failed: Connection refused
[rtmp @ 0x80c10] Cannot open connection tcp://pbp:1935
rtmp://pbp:1935/live/cube: Connection refused
which can be expected, as there is nothing listening on port 1935 on pbp.
Has anybody got ffmpeg  working as a rtmp server or are you using nginx with rtmp support enabled?
Are there other lightweight streaming servers availabe?
Thanks for your help!
(10-26-2020, 09:15 AM)vfr400racer Wrote: On my PinebookPro running Majaro, I try to setup a ffmpeg streaming server.
 I get this error:
Problem was not the listening on the server, but the copy target on the server. Copy to a local file as target works.
ffmpeg is listening, but it can not be seen with ss -a. the correct command is ss -tunlp
Try setting it to your actual ip address instead of localhost
(10-31-2020, 12:20 AM)bhhaskin Wrote: Try setting it to your actual ip address instead of localhost
I tried that before and it didn't make a difference. The problem was, that I was forwarding (copying) the stream to a port where nothing was listening.
Instead of copying to a port, copying to a local file worked well. Recently I installed nginx with the rtmp module (was a bit painful on pbp / manjaro)
but now it is running and is working absolutely perfect.
There is also a docker option that worked really well for me
