UARTs from GPIO headers
Question
I need 4 UARTs, to use board as controller for home automatization: 1 - ZeegBee, 1 - GSM, 1 - RS485, 1 - M-bus. But in documentation, there are only 2 gpio uarts enabled for user. I wouldn't like to use external usb converters, this interfaces should be located on my expansion board, connected to the rock64 by GPIOs. Is there any solutions to solve my problem?
(10-25-2020, 02:23 AM)maks.dav Wrote: I need 4 UARTs, to use board as controller for home automatization: 1 - ZeegBee, 1 - GSM, 1 - RS485, 1 - M-bus. But in documentation, there are only 2 gpio uarts enabled for user. I wouldn't like to use external usb converters, this interfaces should be located on my expansion board, connected to the rock64 by GPIOs. Is there any solutions to solve my problem?
no solution for 4 UARTs from GPIO
There is only 2 UARTs on header, UART2 and UART1 if DT is changed accordingly !
But you can add a SC16IS750 on SPI bus, that will provide 2 additional UARTs ...
(10-27-2020, 12:08 PM)martinayotte Wrote: There is only 2 UARTs on header, UART2 and UART1 if DT is changed accordingly !
Thank you so much for answer, it's a good idea!
May be you know any normal tutorial, how to add and configure chips like SC16IS750 in system and add new serial ports to /dev?
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 21,642 01-15-2023, 10:36 AM
Last Post: ds00
  Configuring Python GPIO Pin Control Rock64 www139 3 12,918 06-22-2021, 06:57 AM
Last Post: Mrfixit2001
  Help connecting a dvb board in the right gpio pins cosmodeal 0 3,633 11-11-2020, 12:48 PM
Last Post: cosmodeal
  GPIO extension cable fault viguzzz 12 22,711 05-18-2018, 04:03 AM
Last Post: viguzzz
Question Rock64 GPIO Nak64Rbit 5 11,466 04-04-2018, 12:53 AM
Last Post: hryst
  gpio driver porting from an r-pi3b gene83 9 17,602 12-02-2017, 03:44 AM
Last Post: xalius
