10-21-2020, 05:23 PM
(This post was last modified: 10-21-2020, 06:17 PM by duncan_bayne.)
		I recently purchased a EB-BJ700CBE battery from eBay, and can confirm the FAQ note:
The EB-BJ700CBE is indeed physically incompatible with the Braveheart Edition PinePhone, due to small plastic feet on the bottom of the battery:
![[Image: image-20087aa2-214e-421a-aee9-bbdd287b74d0.jpg]](https://i.postimg.cc/Bts5S9TC/image-20087aa2-214e-421a-aee9-bbdd287b74d0.jpg)
However! A few seconds with a Dremel and a sanding drum, and the feet were no more:
![[Image: image-1a68c320-020c-4974-8e11-0f3b13715896.jpg]](https://i.postimg.cc/hJd8jKZ2/image-1a68c320-020c-4974-8e11-0f3b13715896.jpg)
The battery now fits, and seems to work as expected. To be super clear, I'm not 100% sure of the electrical compatibility, despite it appearing to work just fine (takes a charge, and runs the phone without issue). But the physical compatibility was an easy fix - just remove the little plastic feet.
Quote:There is a report that model "EB-BJ700CBE" might be incompatible
