copy and pasting from various sources
I was going to post my inxi info here but I can't figure out how to copy and paste from the terminal to something I could put here.
You also need to use shift in addition to the normal shortcut keys to copy/paste in terminal.
copy: ctrl + shift + C
paste: ctrl + shift + V
Depends how you want to achieve this. You could redirect stdout and post it as an attachment:
inxi > info.txt
inxi | tee info.txt
see attached
.txt   info.txt (Size: 2.63 KB / Downloads: 513)
  Quick question abtut sources.list jojuma 1 2,713 06-17-2024, 04:46 AM
Last Post: zetabeta
  How do you copy and paste into mobian terminal? Do you ssh instead? temp0rary 6 11,142 06-01-2021, 12:16 PM
Last Post: temp0rary
