Programming
1) How should I access the camera from my program? Is the camera V4L-compatible, requiring C-level programming? Or can I access it with higher level languages like Java?
2) On a related note, how should the hardware be accessed in general? Is everything accessed through the kernel API's, or are there higher level API's?
You'll likely find that Java will use something like V4L to access the camera. If the driver is there it's just a case of talking to the camera through some Linux interface like V4L. You should be able to to use V4L to probe which camera devices it detects - if you get nothing check the outputs of `dmesg` on boot, `lshw` and `lsusb`.
Every device that is detected is mapped to a file by the Kernel. Checkout the kernel APIs, they'll be your best bet.
Users browsing this thread:
