just in case it helps anyone, I couldn't find a way to open the sd slot cover on mine. A bit of stray glue seem seems to have got onto the inside just there. After taking the back off and removing the excess glue it's now operable, however the alignment of the slot and the case makes it really difficult to insert and remove cards. Is this typical of others experience? I'm just wondering if I haven't put the back on properly.
| Pinetab2: (multi)boot normal image on eMMC and some OS on SD- card | Bart | 4 | 6,301 |
05-31-2025, 02:34 PM Last Post: stevepaesani |
| Booting from SD card on Pinetab2 | samochimaaron | 10 | 11,795 |
08-23-2023, 09:38 AM Last Post: diederik |
| Unable to boot off SD card | gdsmit1 | 5 | 10,600 |
12-30-2020, 03:24 PM Last Post: gdsmit1 |
| Keyboard issues? | hedlund | 4 | 9,006 |
09-11-2020, 07:25 AM Last Post: Lex-2008 |
