09-08-2020, 01:12 PM
Cant really find any information about HackRF on Alpine online.
Shooting for this first..
https://github.com/pavsa/hackrf-spectrum-analyzer
Does anyone have information about getting HackRF running?
I have found alternative APK equivalent packages for LibUSB, FFTW, and default-jdk.
Linux:
See Also: https://github.com/mossmann/hackrf
Linux:
- To run, ensure these packages are installed (exact name depends on distro):
libusb-1.0 libfftw3 default-jdk - Newer openjdk might work also, not tested. On Ubuntu 18.04:
sudo apt install libusb-1.0 libfftw3-bin default-jdk - Follow the HackRF USB permissions setup - you have to add rules to udev to allow hackrf library to open the HackRF USB device, it does not work by default.
- --> "(The following things have been tested on Ubuntu and Gentoo and may need to be adapted to other Linux distributions. In particular, your distro may have a group named something other than plugdev for this purpose.)
To do that, you need to create a new rules file in the
Code:/etc/udev/rules.d - folder. I called mine
Code:52-hackrf.rules - . Here is the content:
Code:ATTR{idVendor}=="1d50", ATTR{idProduct}=="604b", SYMLINK+="hackrf-jawbreaker-%k", MODE="660", GROUP="plugdev"
ATTR{idVendor}=="1d50", ATTR{idProduct}=="6089", SYMLINK+="hackrf-one-%k", MODE="660", GROUP="plugdev"
ATTR{idVendor}=="1fc9", ATTR{idProduct}=="000c", SYMLINK+="hackrf-dfu-%k", MODE="660", GROUP="plugdev" - "
