RAM overclocking
Hey @a-wai just a quick question. Do you go back and turn down the RAM overclock that seems to be coming with uboot as of 2 months ago or are you using it as-is with the new crust update?
You seem to have the only stable build I have with phosh and I thought the others were putting in overclocks (which they were), but now it looks like it is built into the new uboot to 624MHz. So I'm trying to narrow down the problem, if it's still memory overclock or something else.
Thanks for your help!
The RAM clock is set to 552MHz on Mobian, the switch to 624 was quickly reverted.
(07-12-2020, 02:59 AM)a-wai Wrote: The RAM clock is set to 552MHz on Mobian, the switch to 624 was quickly reverted.
Thanks! Trying to do some testing and I've been most stable with yours so needed to check some factors.
