sopine socket power problem
I power up my clusterboard with the pine64 power supply (15A).
The clusterboard leds of socket #0 and #1 lights up, but sockets #3 to #6 does not turn on.
I was able to access sopine boards connected in any socket with a USB-Ethernet dongle through SSH.
I use the sopine armbian-focal img and sopine armbian-bionic images, with a modified dtb file to include 'allwinner,tx-delay-ps = <500>;' following: https://forum.armbian.com/topic/9402-eth...ne-module/.
With this modification I was able to see eth0 device with ifconfig next to my usb-dongle, but only if I connect the Sopine Board on socket #0 or #1. In the rest of the sockets the SOPINE led is on, but not the corresponding clusterboad led and the eth0 device is not listed (only my usb-dongle).
I think my clusterboard is malfunctioning.
I will try with an ATX power supply in the following days.
Any clue what could be wrong?
Also even if I have eth0 interfaces up with a correct ip in socket #0 and #1, they can not ping each other through the internal switch.
Same behavior powering the clusterboard through an ATX power supply ...
  Selling Clusterboard + 4 sopine xblack86 7 15,107 09-26-2022, 03:09 AM
Last Post: poVoq
  SOPine modules stay off at reboot? PeterKeuning 32 68,127 08-17-2021, 11:11 AM
Last Post: renze
  Network problems (actually bad power supply) Unkn0wn 14 31,354 12-01-2019, 10:02 AM
Last Post: venix1
  Power Switch AZClusterboard 1 5,108 02-16-2019, 06:55 AM
Last Post: mdmbc
  Individual SOPINE Power On After Shutdown? Pine 2 6,939 01-30-2019, 08:04 AM
Last Post: mdmbc
  How much force does it take to insert a SOPINE module? jbobspants 0 3,687 01-17-2019, 12:15 PM
Last Post: jbobspants
  Compiling on the Sopine Cluster khaosgrille 3 9,585 08-10-2018, 06:17 AM
Last Post: khaosgrille
  Kubernetes on SoPine cluster part.1 maya.b 3 11,510 04-18-2018, 08:31 AM
Last Post: PigLover
  Question on the power resistors bergera 2 6,858 02-15-2018, 08:20 AM
Last Post: bergera
  sopine cluster thermal images maya.b 4 11,718 12-29-2017, 02:51 PM
Last Post: Luke
