Can I run Ubuntu 18.04?
Is it possible to run Ubuntu 18.04 arm desktop version?
I require software that is only available on Ubuntu 18.04. I know Ubuntu 16.04 desktop works on pine64 but it is too old.
As Ubuntu is derived from Debian you could maybe try a similar approach as here: https://forum.pine64.org/showthread.php?tid=9016
(02-29-2020, 01:23 PM)Boern Wrote: As Ubuntu is derived from Debian you could maybe try a similar approach as here: https://forum.pine64.org/showthread.php?tid=9016
Debian crashes every-time i try to install packages using apt.
Debian is very unstable as I had to reboot it 7 times already.
(02-28-2020, 02:35 PM)supermagic Wrote: Is it possible to run Ubuntu 18.04 arm desktop version?
  I believe I read on an UBPorts forum they are planning to go to Ubuntu
18.04 or 20.04 . . . .  "eventually"  ....
But they are concentrating on 16.04 for now as they figure that is the quickest way for them to offer a "Working"  OS for the pinephone.
  The change has been complicated by so many changes made by the newer OSes.
If you just want an 'out of the box' working 18.04 or 20.04 OS you will have to wait,
 but if you can get your hands dirty working under the hood, you may be able to 'build your own'.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Signal on Ubuntu Touch Kimberley van Buyten 1 6,240 05-26-2022, 05:14 AM
Last Post: fxc
  Loving Ubuntu Touch! But no MMS?!? remington_luger 3 7,271 08-22-2021, 09:55 AM
Last Post: remington_luger
  What would be the right Pinephone OS for me? (mainly from Ubuntu background dev) jcun4128 7 11,804 01-24-2021, 06:01 AM
Last Post: ryo
  Flashing SC card for Ubuntu Touch thorensjubilee 2 6,638 12-15-2020, 07:38 AM
Last Post: thorensjubilee
  How do I install a OS onto a Pine64 using Ubuntu? sportsbkrider 1 4,187 11-19-2020, 02:51 PM
  UBUNTU DOING ALL BUT MAKE/RECEIVE CALLS snow season 2 6,901 11-16-2020, 01:37 PM
Last Post: MonCon
  Ubuntu Touch ? bcnaz 4 9,731 11-17-2019, 06:44 PM
Last Post: bcnaz
