pmbootstrap on Mac OSX
I do not own pinebook pro (linux computer) yet so I tried to install phosh w/ a Macbook terminal
from top to buttom:
$ curl -O https://bootstrap.pypa.io/get-pip.py
$ sudo python3 get-pip.py
$ pip3 --version
$ pip3 install pmbootstrap
$ pmbootstrap init
$ pmbootstrap install --sdcard=/dev/mmcblk0
$ pmbootstrap install --sdcard=/dev/sda
last two commands both generate:
[06:25:26] *** (1/5) PREPARE NATIVE CHROOT ***
[05:29:26] ERROR: [Errno 2] No such file or directory: '/proc/mounts'
[05:29:26] See also: <https://postmarketos.org/troubleshooting>
Run 'pmbootstrap log' for details.
Anyone knows what i'm doing wrong?
(02-29-2020, 07:37 AM)srfne Wrote: Anyone knows what i'm doing wrong?
Yes, you're running pmbootstrap on macOS. We do not support it as we require Linux kernel specific features.
You can install Linux on your Macbook though with bootcamp.
Also, such questions are better asked on our Matrix channel.
Wow. Amazing! That was a fast answer. Smile I was able to do it with a VM. For who wants to do the same, I needed to do 1 extra thing before I could access my sdcard via the VM:
$ cd "/Users/development/VirtualBox VMs"
$ sudo VBoxManage internalcommands createrawvmdk -filename ./sd-card.vmdk -rawdisk /dev/diskXXX
$ sudo chmod 777 /dev/diskXXX
$ sudo chmod 777 ./sd-card.vmdk
After this I need to select the .vmdk in the settings of my VM and I could start the normal pmbootstrap process.
  pmbootstrap error lat 2 8,217 12-22-2020, 06:32 PM
Last Post: lat
  pmbootstrap issues IVp 3 10,656 09-24-2020, 02:24 AM
Last Post: Pinethom
  pmbootstrap build large keyboard not usable u20200719 5 12,341 07-25-2020, 02:31 PM
Last Post: u20200719
  pmbootstrap to sdcard Jeb5Blovrueb 34 80,095 07-07-2020, 04:17 AM
Last Post: fernando_c_m
  Is it possible to pre-configure wifi and ssh with pmbootstrap? kelbot 2 9,146 07-06-2020, 01:55 AM
Last Post: ChriChri
  Dumb question: do I have to use pmbootstrap? quixote 5 11,720 06-11-2020, 09:23 AM
Last Post: plainenough
  Does pmbootstrap install the latest image? mypine 4 12,103 02-20-2020, 01:02 PM
Last Post: mypine
  pmbootstrap - choose different ui after first run mypine 2 7,395 02-13-2020, 04:35 PM
Last Post: mypine
  pmbootstrap to sdcard on debian 10 ctsm63 2 7,600 01-29-2020, 03:53 PM
Last Post: ctsm63
