ARMBand an easily configured Home Media Server
Video
Hi all,
I'm working on a Home Media Server project for automate the process of downloading series and movies and organize your media library.
The project will easy the process of deployment a lot of great existing projects out there for a home server / personal cloud such as Plex, Emby, Radarr, CouchPotato, onwCLoud, ...
If you're interested in making a RockPro64 a Media Server, say hello to ARMBand. Big Grin
The underling Bits:
ARMBand is a fork of Cloudbox for the arm64 architecture. Cloudbox can configure a impressive list of services for home media server without much user work envolved but only supports amd64 architecture. Cloudbox uses Ansible to configure media server related services using Docker containers.  Ansible is an infrastructure automation technology (like Puppet and Chef, but much more easily to start playing with).
Porting Cloudbox to arm64 basically envolves changing Ansible recipes to use arm64 based docker images, fork docker images and adapt scripts to download arm64 packages.
If anyone is interested in contributing in development or testing drop me a msg, ok?
Thanks.
Main Project:
https://github.com/dibrz/ARMBand
Cloudbox Wiki:
https://github.com/Cloudbox/Cloudbox/wiki
https://github.com/dibrz/ARMBand easily maintain an ARM64 media server
(08-08-2018, 06:47 AM)gabrielsr Wrote: Hi all,
The underling Bits:
Thanks.
Main Project:
Cloudbox Wiki:
Guys, I need some help.
I installed the linux version below:
https://wiki.pine64.org/index.php/ROCKPr....5B5.90.5D
I installed the latest Ansible:
     sudo apt update      sudo apt install software-properties-common      sudo apt-add-repository --yes --update ppa: ansible / ansible      sudo apt install ansible
And I'm trying to install the latest CloudBox:
or
When trying to install the CloudBox, I came across the following problem:
TASK [settings : Start | Install ruamel.yaml] ************************************************************************************************************************ fatal: [localhost]: FAILED! => {"changed": false, "msg": "Unable to find any of pip3 to use.  pip needs to be installed."}     to retry, use: --limit @/home/eduapof/Downloads/CloudBox/Cloudbox-master/cloudbox.retry PLAY RECAP ************************************************************************************************************
What should I do? Help!
The underling Bits:
Thanks.
Main Project:
Cloudbox Wiki:
or
sudo apt-get install pip3 I guess
pip3 being the pyhton3 package manager pip being python2
Personally I would just use the OMV images make sure OMV-extras is installed and it has everything + more
OMV is far more than just NAS its just a brilliant server webgui with docker and a whole collection of media containers and utils
Dunno why its so strongly marketed as NAS and not just a complete modular server system
https://wiki.pine64.org/index.php/ROCKPr...5B0.8.3.5D
  Home Server with RAID 1 SATA M2 SSDs runyor 8 24,111 01-22-2025, 04:40 AM
Last Post: Davidmenk3
  Smart TV & server storz 1 5,092 01-19-2024, 01:59 PM
Last Post: dairymilkbatman
  Umbrel Server Shaeroden 0 4,425 05-04-2022, 06:14 PM
Last Post: Shaeroden
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 27,107 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 8,984 01-17-2021, 11:33 AM
  [WIP] backup server (4 sata HDDs + ZFS) rolando 8 19,862 06-30-2020, 10:58 AM
Last Post: dml-pc
  OMV + VPN server + Pi Hole? odhinnhrafn 3 13,818 03-16-2020, 05:01 PM
Last Post: mabs
