How to check if my power supply is underperforming?
Hey guys, I'm having this issue with my external hard drive disconnecting and I'm suspecting my power supply is underperforming.
It's not the official power supply, it's a generic one I found on a store nerby. Except from this suspicion regarding the external HDD, it never showed any sign of problem.
In the Raspberry Pi there's the lightning symbol that shows the undervoltage situation, what about the Rock64? Is there any log or diagnostic tool to track and see if the power supply is underperforming, or if the USB 3 port is not outputing 5V?
Thanks.
I checked the GPIO pins with a multimeter while a USB2.0 HDD was connected to the USB3.0 port.
I'm getting sustained 4,4 to 4,6V in the 5V pin.
Should I conclude that the power supply is underperforming?
Can someone recommend a legit power supply from Aliexpress/Gearbest/Banggood (or somewhere that ships to South America at a reasonable price)?
what are you Power Supply says, how mutch Ampere it can deliver?
The official is 5V - 3A
(06-02-2019, 07:37 AM)gigagames Wrote: Hello,
The power supply says it delivers 5V3A, but it looks like that's not true.
Under very little load it's below 5V.
I ordered a USB Voltage meter to check the amperage anyways.
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,518 03-24-2025, 06:41 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 21,685 01-15-2023, 10:36 AM
Last Post: ds00
  power connector type please AlexS 4 10,243 01-11-2023, 07:00 AM
Last Post: dmitrymyadzelets
  Alternative power supply ju0n 0 3,924 09-06-2022, 02:46 AM
Last Post: ju0n
  Which Voltage and Amper to supply both Rock64 + External drive enclosure ? prog-amateur 0 4,017 08-21-2020, 09:16 PM
Last Post: prog-amateur
  Power Supply and Sinks for multi-Rock64 env Davo-CC 1 6,402 01-02-2020, 02:26 PM
Last Post: dpgraham
  Using a stronger power supply myn4m3 1 4,770 06-23-2019, 05:01 PM
Last Post: Rocklobster
  USB3 enough to power 2,5 external HDD? va88 11 23,437 06-06-2019, 03:40 PM
Last Post: va88
  "ROCK 64 STEREO AUDIO DAC ADD-ON BOARD", Is it okay if I turn on the power ? t4_4t 4 10,334 01-09-2019, 01:02 AM
Last Post: t4_4t
  Boot on power-up vicencb 1 5,055 11-26-2018, 11:45 PM
Last Post: evilbunny
