OMV-Remotedesktop-lag-disorder
Star
I desperately need a Remote Desktop in OMV OpenMediaVault.
Installed> OMV-Extras> Plugins> openmediavault-remotedesktop 4.0.1
Connected via Windows Remote Desktop Connection.
After a few clicks, no reaction, connection reboot few clicks and again lags / errors.
root@rockpro64:~# uname -a
Linux rockpro64 4.4.138-1094-rockchip-ayufan-gf13a8a9a4eee #1 SMP Thu Aug 9 20:29:55 UTC 2018 aarch64 GNU/Linux
[Image: 2Pcg4.jpg] [Image: 2PchY.jpg]
Remote Desktop is very important to me.
Please help.
(12-14-2018, 01:21 PM)Neo2018 Wrote: Hello,
Please help.
So ... Reliable remote desktop can be achieved in two ways in OMV.
1) Using OMV WebBUI: set up your user first an make sure that your user has a home directory (this is a must) as well as elevated privilages (sudoers group) [edit] adding user to sudoers is conveniant, but not necessary. After you set this install the RDP plugin. From here its pretty straight forgward - you connect using your OMV credentials.
2) VNC server: the alternative route is to install VNC from CLI (which I prefer) - you'll still have to make your user have a home folder and I suggest you add user to sudeors. Then install the destkop you want - I suggest mate, xfce or lxde. Reboot. After ssh into the OMV install and install your favorite VNC server.
I've tried both and in my experience both work well.
(12-14-2018, 02:00 PM)Luke Wrote: 1) Using OMV WebBUI: set up your user first an make sure that your user has a home directory (this is a must) as well as elevated privilages (sudoers group) [edit] adding user to sudoers is conveniant, but not necessary. After you set this install the RDP plugin. From here its pretty straight forgward - you connect using your OMV credentials.
Hello, thanks for the answer
Way 1) Does not work no matter which user I take. After a few clicks Lag everything.
[Image: 2Pdiw.jpg]Am I doing something wrong or forgotten?
I think you may also want to ask over at OMV forum about the rdp plugin. Personally I run vnc4server on OMV with a mate and have not experienced any issues.
(12-15-2018, 06:06 AM)Luke Wrote: I think you may also want to ask over at OMV forum about the rdp plugin. Personally I run vnc4server on OMV with a mate and have not experienced any issues.
As you know (from this post) I also use a RaspberryPi also with OMV and OMV-Extras> Plugins> openmediavault-remotedesktop 4.0.1. Since I have no problems everything works 100%. It MUST be on RockPro64 or OS. Have tried different images Debian Stretch Minimal aarch64 / OpenMediaVault Stretch armhf both same mistakes.
(There are unfortunately several bugs with RockPro)
I will inevitably try it with VNC take. I wanted to avoid external services.
Well, perhaps if you provide logs it will be easier to detrmine the issue. Please pastebin them - both syslog and rdp log.
Also, have you tried mainline ? I run on 4.19 and have no issues (32bit version)
(12-15-2018, 03:52 PM)Luke Wrote: Well, perhaps if you provide logs it will be easier to detrmine the issue. Please pastebin them - both syslog and rdp log.
I am so angry. Everything I try does not work. It must be easy to install.
In the openmediavault forum, OMV-Remote Desktop-lag-disorder
Please give step by step instructions for VNC installation.
I solved the problem. In my case, the stretch-openmediavault-rockpro64-0.7.9-1067-armhf.img was the problem.
Only with this stretch-openmediavault-rockpro64-0.7.11-1075-armhf.img everything works very well (until now)
Thanks to ryecoaaron, only he could help me.
(12-14-2018, 02:00 PM)Luke Wrote: So ... Reliable remote desktop can be achieved in two ways in OMV.
It is not necessary to create a home directory and assign sudo rights for user. With root login works perfectly.
