Centos 7 on rock64
I want to run Centos 7 on rock64 rk3328 chipset. Any sort of help is appreciated.
Regards,
(10-29-2018, 04:23 AM)smnoufal Wrote: I want to run Centos 7 on rock64 rk3328 chipset. Any sort of help is appreciated.
Regards,
Hi smnoufal,
I would try to see if you can get any armbian rock64 distribution to work on it. If that works then you can try sliding the centos 7 file system on it. For inspiration see what I did for pine64 here:
https://github.com/Project31/centos-pine64
Cheers,
--Kurt
Regards,
Hi smnoufal,
Cheers,
--Kurt
Thanks Kurt,
I will have a look on the above link.
Regards,
Hi smnoufal,
Cheers,
--Kurt
Thanks Kurt,
Hi Kurt,
I have inserted empty microsd and run install.sh, i am stuck on screenshot attached
Hi smnoufal,
You can try the ready to go image: https://project31.github.io/pine64/. I've created it running from the rock64 branch on https://github.com/Project31/centos-pine64/tree/rock64.
Cheers,
--Kurt
Thanks Kurt, for centos 7 on rock64,
I followed your instruction and glad to inform you that successfully loaded cenntos 7. once i tried to enlarge the sd card and rebooted as per your  instruction and it ffiled to boot. I think partition got deleted.
smnoufal
kurtstamHi smnoufal,
Cheers,
--Kurt
Log in
to use Ginger
Limited mode
centos
[url=javascript:]×[/url]
Hi  smnoufal,
1. So I take it then things work ok /before/ you try to enlarge the partition on the sd card?
2. I would re-flash the image and start over. I would try to take baby steps so you can pinpoint what works for you. Whenever you work fdisk you have to be careful.. Double check:
  1. name of the device (/dev/rdisk)
  2. using fdisk, use `p` to list the partitions
3. Try to capture the output when following the instructions and post it here. That can be helpful.
Cheers,
--Kurt
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 10,595 10-02-2020, 11:38 AM
Last Post: mathiraj
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 17,534 03-28-2020, 06:20 PM
Last Post: ty1911
  Centos 7 for Pine A64 Luke 2 11,235 05-28-2019, 12:18 AM
Last Post: pineadmin
  Centos 7 ebrand 12 32,261 01-12-2019, 06:40 PM
Last Post: astr0baby
  Making a DVD Server (including burning) using Rock64 Ron Piggott 1 5,572 04-11-2018, 08:33 AM
Last Post: dkryder
