GPIO extension cable fault
Sorry for the long time since last reply!
well... I can confirm two things now:
1) this issue is caused by something connected on GPIOs mentioned by pfeerick (from32 to 40 in PI-2) (thanks for the advice!!)
2) this exists only if running from SD, if running from eMMC I may connect everything on all GPIO without problem!
thanks to all for the precious support!!
Viguzzz
(05-17-2018, 08:04 AM)viguzzz Wrote: Sorry for the long time since last reply!
Viguzzz
Hm... interesting... I think it's more than just something connected as I was able to reproduce that without anything connected to the ribbon, but I'm glad you resolved your issue regardless Smile Happy hacking!
(05-18-2018, 03:45 AM)pfeerick Wrote: ... I think it's more than just something connected as I was able to reproduce that without anything connected to the ribbon....
Sorry for misunderstood, I was meaning that this happens when wire only ( as you suggested I've tried with single wire instead of ribbon) are connected to GPIO pin from 32 to 40 and nothing is connected on other side, other pins are not involved in this issue.
I've not encountered this issue  using eMMC.
Thanks Again
Viguzzz
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 49,296 03-24-2025, 06:35 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 21,947 01-15-2023, 10:36 AM
Last Post: ds00
  Configuring Python GPIO Pin Control Rock64 www139 3 13,063 06-22-2021, 06:57 AM
Last Post: Mrfixit2001
  Help connecting a dvb board in the right gpio pins cosmodeal 0 3,671 11-11-2020, 12:48 PM
Last Post: cosmodeal
Question UARTs from GPIO headers maks.dav 3 8,308 10-30-2020, 07:44 AM
Last Post: maks.dav
  USB3 to SATA cable - Firmware Eule 0 3,615 03-03-2020, 01:31 PM
Last Post: Eule
  PCIe extender cable for M2 grimace 1 4,278 02-15-2019, 11:15 AM
Last Post: fonix232
Bug Rock64 Boot-up Bug with Serial Console Cable MarkHaysHarris777 1 10,448 04-13-2018, 03:45 AM
Last Post: Z80
Question Rock64 GPIO Nak64Rbit 5 11,592 04-04-2018, 12:53 AM
Last Post: hryst
  gpio driver porting from an r-pi3b gene83 9 17,804 12-02-2017, 03:44 AM
Last Post: xalius
