Sound quality from audio jack
I have gotten sounds working using the instructions over here.
Thread Modes Use Audiojack instead of HDMI audio
The sound quality seems very poor though.  I'm using this to replace an RPiA that I just cant deal with anymore.
I'm trying to produce a low frequency sine sweep with the following command:
play -n synth 10 sine 30:45
I can hear it but there appears to be a lot of distortion, or perhaps the incorrect frequency.  Anything to check on how this is setup?
Here are my alsamixer settings:
root@DietPi:~# cat /var/lib/alsa/asound.state state.sndhdmi {         control.1 {                 iface MIXER                 name 'hdmi audio format Function'                 value pcm                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 null                         item.1 pcm                         item.2 AC3                         item.3 MPEG1                         item.4 MP3                         item.5 MPEG2                         item.6 AAC                         item.7 DTS                         item.8 ATRAC                         item.9 ONE_BIT_AUDIO                         item.10 DOLBY_DIGITAL_PLUS                         item.11 DTS_HD                         item.12 MAT                         item.13 WMAPRO                 }         } } state.audiocodec {         control.1 {                 iface MIXER                 name 'AIF1 ADC timeslot 0 volume'                 value.0 166                 value.1 166                 comment {                         access 'read write'                         type INTEGER                         count 2                         range '0 - 255'                         dbmin -11925                         dbmax 7200                         dbvalue.0 525                         dbvalue.1 525                 }         }         control.2 {                 iface MIXER                 name 'AIF1 ADC timeslot 1 volume'                 value.0 160                 value.1 160                 comment {                         access 'read write'                         type INTEGER                         count 2                         range '0 - 255'                         dbmin -11925                         dbmax 7200                         dbvalue.0 75                         dbvalue.1 75                 }         }         control.3 {                 iface MIXER                 name 'AIF1 DAC timeslot 0 volume'                 value.0 160                 value.1 160                 comment {                         access 'read write'                         type INTEGER                         count 2                         range '0 - 255'                         dbmin -11925                         dbmax 7200                         dbvalue.0 75                         dbvalue.1 75                 }         }         control.4 {                 iface MIXER                 name 'AIF1 DAC timeslot 1 volume'                 value.0 160                 value.1 160                 comment {                         access 'read write'                         type INTEGER                         count 2                         range '0 - 255'                         dbmin -11925                         dbmax 7200                         dbvalue.0 75                         dbvalue.1 75                 }         }         control.5 {                 iface MIXER                 name 'AIF1 ADC timeslot 0 mixer gain'                 value.0 11                 value.1 11                 comment {                         access 'read write'                         type INTEGER                         count 2                         range '0 - 15'                         dbmin -600                         dbmax 8400                         dbvalue.0 6000                         dbvalue.1 6000                 }         }         control.6 {                 iface MIXER                 name 'AIF1 ADC timeslot 1 mixer gain'                 value.0 2                 value.1 2                 comment {                         access 'read write'                         type INTEGER                         count 2                         range '0 - 3'                         dbmin -600                         dbmax 1200                         dbvalue.0 600                         dbvalue.1 600                 }         }         control.7 {                 iface MIXER                 name 'AIF2 ADC volume'                 value.0 166                 value.1 166                 comment {                         access 'read write'                         type INTEGER                         count 2                         range '0 - 255'                         dbmin -11925                         dbmax 7200                         dbvalue.0 525                         dbvalue.1 525                 }         }         control.8 {                 iface MIXER                 name 'AIF2 DAC volume'                 value.0 160                 value.1 160                 comment {                         access 'read write'                         type INTEGER                         count 2                         range '0 - 255'                         dbmin -11925                         dbmax 7200                         dbvalue.0 75                         dbvalue.1 75                 }         }         control.9 {                 iface MIXER                 name 'AIF2 ADC mixer gain'                 value.0 11                 value.1 11                 comment {                         access 'read write'                         type INTEGER                         count 2                         range '0 - 15'                         dbmin -600                         dbmax 8400                         dbvalue.0 6000                         dbvalue.1 6000                 }         }         control.10 {                 iface MIXER                 name 'ADC volume'                 value.0 160                 value.1 160                 comment {                         access 'read write'                         type INTEGER                         count 2                         range '0 - 255'                         dbmin -11925                         dbmax 7200                         dbvalue.0 75                         dbvalue.1 75                 }         }         control.11 {                 iface MIXER                 name 'DAC volume'                 value.0 0                 value.1 0                 comment {                         access 'read write'                         type INTEGER                         count 2                         range '0 - 255'                         dbmin -11925                         dbmax 7200                         dbvalue.0 -11925                         dbvalue.1 -11925                 }         }         control.12 {                 iface MIXER                 name 'DAC mixer gain'                 value.0 11                 value.1 11                 comment {                         access 'read write'                         type INTEGER                         count 2                         range '0 - 15'                         dbmin -600                         dbmax 8400                         dbvalue.0 6000                         dbvalue.1 6000                 }         }         control.13 {                 iface MIXER                 name 'digital volume'                 value 0                 comment {                         access 'read write'                         type INTEGER                         count 1                         range '0 - 63'                         dbmin -7308                         dbmax 0                         dbvalue.0 -7308                 }         }         control.14 {                 iface MIXER                 name 'earpiece volume'                 value 25                 comment {                         access 'read write'                         type INTEGER                         count 1                         range '0 - 31'                         dbmin -4350                         dbmax 300                         dbvalue.0 -600                 }         }         control.15 {                 iface MIXER                 name 'speaker volume'                 value 26                 comment {                         access 'read write'                         type INTEGER                         count 1                         range '0 - 31'                         dbmin -4800                         dbmax -150                         dbvalue.0 -900                 }         }         control.16 {                 iface MIXER                 name 'headphone volume'                 value 51                 comment {                         access 'read write'                         type INTEGER                         count 1                         range '0 - 63'                         dbmin -6300                         dbmax 0                         dbvalue.0 -1200                 }         }         control.17 {                 iface MIXER                 name 'MIC1_G boost stage output mixer control'                 value 3                 comment {                         access 'read write'                         type INTEGER                         count 1                         range '0 - 7'                         dbmin -450                         dbmax 600                         dbvalue.0 0                 }         }         control.18 {                 iface MIXER                 name 'MIC1 boost AMP gain control'                 value 4                 comment {                         access 'read write'                         type INTEGER                         count 1                         range '0 - 7'                         dbmin 0                         dbmax 1400                         dbvalue.0 800                 }         }         control.19 {                 iface MIXER                 name 'MIC2 BST stage to L_R outp mixer gain'                 value 3                 comment {                         access 'read write'                         type INTEGER                         count 1                         range '0 - 7'                         dbmin -450                         dbmax 600                         dbvalue.0 0                 }         }         control.20 {                 iface MIXER                 name 'MIC2 boost AMP gain control'                 value 4                 comment {                         access 'read write'                         type INTEGER                         count 1                         range '0 - 7'                         dbmin 0                         dbmax 1400                         dbvalue.0 800                 }         }         control.21 {                 iface MIXER                 name 'LINEINL/R to L_R output mixer gain'                 value 5                 comment {                         access 'read write'                         type INTEGER                         count 1                         range '0 - 7'                         dbmin -450                         dbmax 600                         dbvalue.0 300                 }         }         control.22 {                 iface MIXER                 name 'ADC input gain control'                 value 3                 comment {                         access 'read write'                         type INTEGER                         count 1                         range '0 - 7'                         dbmin -450                         dbmax 600                         dbvalue.0 0                 }         }         control.23 {                 iface MIXER                 name 'Phoneout gain control'                 value 5                 comment {                         access 'read write'                         type INTEGER                         count 1                         range '0 - 7'                         dbmin -450                         dbmax 600                         dbvalue.0 300                 }         }         control.24 {                 iface MIXER                 name 'SRC FUCTION'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.25 {                 iface MIXER                 name 'I2S HUB FUNC'                 value false                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.26 {                 iface MIXER                 name 'Phoneout Mixer MIC1 boost Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.27 {                 iface MIXER                 name 'Phoneout Mixer MIC2 boost Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.28 {                 iface MIXER                 name 'Phoneout Mixer Rout_Mixer_Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.29 {                 iface MIXER                 name 'Phoneout Mixer Lout_Mixer_Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.30 {                 iface MIXER                 name 'ADCR Mux'                 value DMIC                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 ADC                         item.1 DMIC                 }         }         control.31 {                 iface MIXER                 name 'ADCL Mux'                 value DMIC                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 ADC                         item.1 DMIC                 }         }         control.32 {                 iface MIXER                 name 'MIC2 SRC'                 value MIC2                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 MIC3                         item.1 MIC2                 }         }         control.33 {                 iface MIXER                 name 'RADC input Mixer MIC1 boost Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.34 {                 iface MIXER                 name 'RADC input Mixer MIC2 boost Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.35 {                 iface MIXER                 name 'RADC input Mixer LINEINR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.36 {                 iface MIXER                 name 'RADC input Mixer r_output mixer Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.37 {                 iface MIXER                 name 'RADC input Mixer l_output mixer Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.38 {                 iface MIXER                 name 'RADC input Mixer PHONINN Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.39 {                 iface MIXER                 name 'RADC input Mixer PHONINN-PHONINP Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.40 {                 iface MIXER                 name 'LADC input Mixer MIC1 boost Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.41 {                 iface MIXER                 name 'LADC input Mixer MIC2 boost Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.42 {                 iface MIXER                 name 'LADC input Mixer LINEINL Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.43 {                 iface MIXER                 name 'LADC input Mixer l_output mixer Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.44 {                 iface MIXER                 name 'LADC input Mixer r_output mixer Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.45 {                 iface MIXER                 name 'LADC input Mixer PHONINP Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.46 {                 iface MIXER                 name 'LADC input Mixer PHONINP-PHONINN Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.47 {                 iface MIXER                 name 'AIF3OUT Mux'                 value 'AIF2 ADC left channel'                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 'AIF2 ADC left channel'                         item.1 'AIF2 ADC right channel'                 }         }         control.48 {                 iface MIXER                 name 'AIF2 ADR Mixer AIF1 DA0R Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.49 {                 iface MIXER                 name 'AIF2 ADR Mixer AIF1 DA1R Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.50 {                 iface MIXER                 name 'AIF2 ADR Mixer AIF2 DACL Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.51 {                 iface MIXER                 name 'AIF2 ADR Mixer ADCR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.52 {                 iface MIXER                 name 'AIF2 ADL Mixer AIF1 DA0L Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.53 {                 iface MIXER                 name 'AIF2 ADL Mixer AIF1 DA1L Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.54 {                 iface MIXER                 name 'AIF2 ADL Mixer AIF2 DACR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.55 {                 iface MIXER                 name 'AIF2 ADL Mixer ADCL Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.56 {                 iface MIXER                 name 'AIF2INR Mux'                 value AIF2_DACR                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 AIF2_DACR                         item.1 AIF2_DACL                         item.2 SUM_AIF2DACL_AIF2DACR                         item.3 AVE_AIF2DACL_AIF2DACR                 }         }         control.57 {                 iface MIXER                 name 'AIF2INL Mux'                 value AIF2_DACL                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 AIF2_DACL                         item.1 AIF2_DACR                         item.2 SUM_AIF2DACL_AIF2DACR                         item.3 AVE_AIF2DACL_AIF2DACR                 }         }         control.58 {                 iface MIXER                 name 'AIF2OUTR Mux'                 value AIF2_ADCR                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 AIF2_ADCR                         item.1 AIF2_ADCL                         item.2 SUM_AIF2_ADCL_AIF2_ADCR                         item.3 AVE_AIF2_ADCL_AIF2_ADCR                 }         }         control.59 {                 iface MIXER                 name 'AIF2OUTL Mux'                 value AIF2_ADCL                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 AIF2_ADCL                         item.1 AIF2_ADCR                         item.2 SUM_AIF2_ADCL_AIF2_ADCR                         item.3 AVE_AIF2_ADCL_AIF2_ADCR                 }         }         control.60 {                 iface MIXER                 name 'EAR Mux'                 value DACR                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 DACR                         item.1 DACL                         item.2 'Right Analog Mixer'                         item.3 'Left Analog Mixer'                 }         }         control.61 {                 iface MIXER                 name 'SPK_L Mux'                 value 'MIXEL Switch'                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 'MIXEL Switch'                         item.1 'MIXL MIXR  Switch'                 }         }         control.62 {                 iface MIXER                 name 'SPK_R Mux'                 value 'MIXER Switch'                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 'MIXER Switch'                         item.1 'MIXR MIXL Switch'                 }         }         control.63 {                 iface MIXER                 name 'HP_L Mux'                 value 'DACL HPL Switch'                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 'DACL HPL Switch'                         item.1 'Left Analog Mixer HPL Switch'                 }         }         control.64 {                 iface MIXER                 name 'HP_R Mux'                 value 'DACR HPR Switch'                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 'DACR HPR Switch'                         item.1 'Right Analog Mixer HPR Switch'                 }         }         control.65 {                 iface MIXER                 name 'Right Output Mixer DACL Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.66 {                 iface MIXER                 name 'Right Output Mixer DACR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.67 {                 iface MIXER                 name 'Right Output Mixer LINEINR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.68 {                 iface MIXER                 name 'Right Output Mixer MIC2Booststage Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.69 {                 iface MIXER                 name 'Right Output Mixer MIC1Booststage Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.70 {                 iface MIXER                 name 'Right Output Mixer PHONEINN Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.71 {                 iface MIXER                 name 'Right Output Mixer PHONEINN-PHONEINP Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.72 {                 iface MIXER                 name 'Left Output Mixer DACR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.73 {                 iface MIXER                 name 'Left Output Mixer DACL Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.74 {                 iface MIXER                 name 'Left Output Mixer LINEINL Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.75 {                 iface MIXER                 name 'Left Output Mixer MIC2Booststage Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.76 {                 iface MIXER                 name 'Left Output Mixer MIC1Booststage Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.77 {                 iface MIXER                 name 'Left Output Mixer PHONEINP Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.78 {                 iface MIXER                 name 'Left Output Mixer PHONEINP-PHONEINN Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.79 {                 iface MIXER                 name 'DACR Mixer ADCR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.80 {                 iface MIXER                 name 'DACR Mixer AIF2DACR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.81 {                 iface MIXER                 name 'DACR Mixer AIF1DA1R Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.82 {                 iface MIXER                 name 'DACR Mixer AIF1DA0R Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.83 {                 iface MIXER                 name 'DACL Mixer ADCL Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.84 {                 iface MIXER                 name 'DACL Mixer AIF2DACL Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.85 {                 iface MIXER                 name 'DACL Mixer AIF1DA1L Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.86 {                 iface MIXER                 name 'DACL Mixer AIF1DA0L Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.87 {                 iface MIXER                 name 'AIF1 AD1R Mixer AIF2 DACR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.88 {                 iface MIXER                 name 'AIF1 AD1R Mixer ADCR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.89 {                 iface MIXER                 name 'AIF1 AD1L Mixer AIF2 DACL Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.90 {                 iface MIXER                 name 'AIF1 AD1L Mixer ADCL Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.91 {                 iface MIXER                 name 'AIF1 AD0R Mixer AIF1 DA0R Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.92 {                 iface MIXER                 name 'AIF1 AD0R Mixer AIF2 DACR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.93 {                 iface MIXER                 name 'AIF1 AD0R Mixer ADCR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.94 {                 iface MIXER                 name 'AIF1 AD0R Mixer AIF2 DACL Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.95 {                 iface MIXER                 name 'AIF1 AD0L Mixer AIF1 DA0L Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.96 {                 iface MIXER                 name 'AIF1 AD0L Mixer AIF2 DACL Switch'                 value false                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.97 {                 iface MIXER                 name 'AIF1 AD0L Mixer ADCL Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.98 {                 iface MIXER                 name 'AIF1 AD0L Mixer AIF2 DACR Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.99 {                 iface MIXER                 name 'AIF1IN1R Mux'                 value AIF1_DA1R                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 AIF1_DA1R                         item.1 AIF1_DA1L                         item.2 SUM_AIF1DA1L_AIF1DA1R                         item.3 AVE_AIF1DA1L_AIF1DA1R                 }         }         control.100 {                 iface MIXER                 name 'AIF1IN1L Mux'                 value AIF1_DA1L                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 AIF1_DA1L                         item.1 AIF1_DA1R                         item.2 SUM_AIF1DA1L_AIF1DA1R                         item.3 AVE_AIF1DA1L_AIF1DA1R                 }         }         control.101 {                 iface MIXER                 name 'AIF1IN0R Mux'                 value AIF1_DA0R                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 AIF1_DA0R                         item.1 AIF1_DA0L                         item.2 SUM_AIF1DA0L_AIF1DA0R                         item.3 AVE_AIF1DA0L_AIF1DA0R                 }         }         control.102 {                 iface MIXER                 name 'AIF1IN0L Mux'                 value AIF1_DA0L                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 AIF1_DA0L                         item.1 AIF1_DA0R                         item.2 SUM_AIF1DA0L_AIF1DA0R                         item.3 AVE_AIF1DA0L_AIF1DA0R                 }         }         control.103 {                 iface MIXER                 name 'AIF1OUT1R Mux'                 value AIF1_AD1R                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 AIF1_AD1R                         item.1 AIF1_AD1L                         item.2 SUM_AIF1ADC1L_AIF1ADC1R                         item.3 AVE_AIF1ADC1L_AIF1ADC1R                 }         }         control.104 {                 iface MIXER                 name 'AIF1OUT1L Mux'                 value AIF1_AD1L                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 AIF1_AD1L                         item.1 AIF1_AD1R                         item.2 SUM_AIF1ADC1L_AIF1ADC1R                         item.3 AVE_AIF1ADC1L_AIF1ADC1R                 }         }         control.105 {                 iface MIXER                 name 'AIF1OUT0R Mux'                 value AIF1_AD0R                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 AIF1_AD0R                         item.1 AIF1_AD0L                         item.2 SUM_AIF1AD0L_AIF1AD0R                         item.3 AVE_AIF1AD0L_AIF1AD0R                 }         }         control.106 {                 iface MIXER                 name 'AIF1OUT0L Mux'                 value AIF1_AD0L                 comment {                         access 'read write'                         type ENUMERATED                         count 1                         item.0 AIF1_AD0L                         item.1 AIF1_AD0R                         item.2 SUM_AIF1AD0L_AIF1AD0R                         item.3 AVE_AIF1AD0L_AIF1AD0R                 }         }         control.107 {                 iface MIXER                 name 'AIF2INR Mux VIR switch aif2inr aif3'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.108 {                 iface MIXER                 name 'AIF2INL Mux VIR switch aif2inl aif3'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.109 {                 iface MIXER                 name 'AIF2INR Mux switch aif2inr aif2'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.110 {                 iface MIXER                 name 'AIF2INL Mux switch aif2inl aif2'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.111 {                 iface MIXER                 name 'External Speaker Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.112 {                 iface MIXER                 name 'Headphone Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         }         control.113 {                 iface MIXER                 name 'Earpiece Switch'                 value true                 comment {                         access 'read write'                         type BOOLEAN                         count 1                 }         } }
thanks,
Devan
  +LTS/SOPINE Audio Jack Pinout Little_Johnny 0 6,074 12-29-2019, 08:44 AM
Last Post: Little_Johnny
  sound amp and speakers for the case Israeldelamo 4 12,606 12-29-2019, 08:38 AM
  Pine64 (analog) Audio Jack Output w/ Kernel 4.19 ecolezen 0 6,238 01-24-2019, 07:00 AM
Last Post: ecolezen
  PINE64 STEREO AUDIO DAC POT jtgiroux 0 6,224 01-12-2019, 04:56 PM
Last Post: jtgiroux
  Enabling wolfson wm8960 i2c/i2s sound codec saro 5 25,052 06-01-2017, 03:04 AM
Last Post: saro
  Audio Extractor Ralck 1 8,351 05-25-2017, 12:25 PM
Last Post: dkryder
Sad Enable Mic on 3.5 jack port saro 14 52,925 03-29-2017, 02:06 AM
Last Post: saro
  Use Audiojack instead of HDMI audio pictus 55 179,531 12-24-2016, 06:03 PM
Last Post: Akiva
