08-07-2017, 10:36 AM
The purpose of this obscure post is to document some modding discussion, high-lighting the lcd module clips and showing some close-ups of the lcd pane.
In the pic(s) above the clips which hold the lcd module in place are clearly seen. What is not clear is whether any glue (sticky goo) has been used as well during the manufacturing process.
Also not certain is what holds the glass pane in place (see pic above) ; I suspect glue or sticky good substance at the edges of the pane. Removing the module may be fairly straight-forward, but removing the necessary glass pane may be a trick; and, the glass pane is definitely needed for touch, and may also be required for proper viewing as well due to the nature of polarized light through the display.
marcushh777
please join us for a chat @ irc.pine64.xyz:6667 or ssl irc.pine64.xyz:6697
( I regret that I am not able to respond to personal messages; let's meet on irc! )
