hello, nice work on 0602 but i noticed a few things. the about allwinner link has bad url and shutdown via command line or upper right power only reboots device, no actual shutdown. what would be best way to shutdown? oh yeah, cortana, what is best suggested method to get the voice recognition working? is there a list of known good mic/speaker setups?
		06-05-2017, 03:32 PM
(This post was last modified: 06-05-2017, 08:47 PM by dkryder.)
		hey, the light [led] does not blink, continuous glow. disconnect probably isn't ok, yeah hopefully doing it this way won't bork sd card. this is a pine64 thing , well my omega2+ also won't shutdown but that's a different show, cause my minnowboard does not have this. another side thing is ethernet is half duplex when fully booted, is this a feature or a bug?  also, command SetDisplayResolution only allows one resolution 1280x720 @ 64Hz. the 64Hz creates overscan. i should be able to open PowerShell, but the command causes command line to grey out for ~20-30 seconds then kicks back to command line.
I’m developing my project on DragonBoard 410C, but I’m looking for a better solution.
Screen resolution limitation of Pine64 was mentioned here. I saw that it’s fixed at 1280x720.
Could someone else confirm that too?
I want to know all of the known issues in Windows IoT Core on Pine64 board. How’s the graphics performing? Is there hardware acceleration or graphics is performing less than optimal? And are there any other performance issues or something that’s not mentioned in official changelog of IoT Core OS?
By the way if we have to look at the official changelog, we have to think that Pine64 board performs better than officially supported boards by Microsoft. But I doubt that. That’s why I’m asking for your help.
Thanks in advance!
Regards, Miroslav.
