Pine64 Installer Utility
Just a quick heads up, the Pine64 Installer Utility is available. It makes it easy to download and flash OS images for your Pine devices. The utility works on Mac OSX, Windows 7/8/10 as well as Linux.
You start by picking an OS image for your device:
You can select the Pine device from a drop down menu. Once you've selected your device and OS, the Pine Installer will fetch the desired OS image:
Once the image has downloaded, simply connect your MicroSD card to your computer. The Pine Installer will recognise it and walk you through the process of flashing the image.
You can discuss the Pine64 Installer here. I have locked the thread to prevent a duplicate discussion.
  How to port Postmarket OS from Pine64-LTS to Pinebook Surehand53 0 3,708 01-16-2019, 08:55 AM
Last Post: Surehand53
  Installer does not work for me Tofu 4 10,018 12-02-2018, 12:55 AM
Last Post: Tofu
Question Installer shows SD Card size 0GB atr.mbl 1 5,299 08-16-2017, 11:13 PM
Last Post: MarkHaysHarris777
  Do I really need PINE64-Installer? anaumov 13 23,857 08-14-2017, 04:47 PM
Last Post: shirman
