Enable Mic on 3.5 jack port
Sad
Hi boys,
I'd followed the guide reported at enable audio on jack instead hdmi
and now I can hear the sound by the headset, but I don't understand
why I can't record by the mic.
Can you help me please?
Tnanks in advance.
You need to configure alsamixer to open the microphone path, try the following settings:
<path name="media-headset-mic">
<ctl name="MIC2 SRC" value="MIC2"/>
<ctl name="LADC input Mixer MIC2 boost Switch" value="1"/>
<ctl name="RADC input Mixer MIC2 boost Switch" value="1"/>
<ctl name="ADCL Mux" value="ADC"/>
<ctl name="ADCR Mux" value="ADC"/>
<ctl name="AIF1 AD0L Mixer ADCL Switch" value="1"/>
<ctl name="AIF1 AD0R Mixer ADCR Switch" value="1"/>
<ctl name="AIF1OUT0L Mux" value="AIF1_AD0L"/>
<ctl name="AIF1OUT0R Mux" value="AIF1_AD0R"/>
<ctl name="ADC volume" value="160"/>
</path>
That seems to be how Android configures the MIC2
Edit: it's MIC2, not MIC1...
(03-27-2017, 04:05 AM)xalius Wrote: You need to configure alsamixer to open the microphone path, try the following settings:
</path>
Thank you so much...
Can you tell me, in Ubuntu, where is the file to update with these, please?
Here my modified /var/lib/alsa/asound.state that match the proposed changes:
state.audiocodec {
    control.1 {
        iface MIXER
        name 'AIF1 ADC timeslot 0 volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.2 {
        iface MIXER
        name 'AIF1 ADC timeslot 1 volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.3 {
        iface MIXER
        name 'AIF1 DAC timeslot 0 volume'
        value.0 153
        value.1 153
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -450
            dbvalue.1 -450
    control.4 {
        iface MIXER
        name 'AIF1 DAC timeslot 1 volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.5 {
        iface MIXER
        name 'AIF1 ADC timeslot 0 mixer gain'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 15'
            dbmin -600
            dbmax 8400
            dbvalue.0 -600
            dbvalue.1 -600
    control.6 {
        iface MIXER
        name 'AIF1 ADC timeslot 1 mixer gain'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 3'
            dbmin -600
            dbmax 1200
            dbvalue.0 -600
            dbvalue.1 -600
    control.7 {
        iface MIXER
        name 'AIF2 ADC volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.8 {
        iface MIXER
        name 'AIF2 DAC volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.9 {
        iface MIXER
        name 'AIF2 ADC mixer gain'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 15'
            dbmin -600
            dbmax 8400
            dbvalue.0 -600
            dbvalue.1 -600
    control.10 {
        iface MIXER
        name 'ADC volume'
        value.0 160
        value.1 160
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.11 {
        iface MIXER
        name 'DAC volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.12 {
        iface MIXER
        name 'DAC mixer gain'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 15'
            dbmin -600
            dbmax 8400
            dbvalue.0 -600
            dbvalue.1 -600
    control.13 {
        iface MIXER
        name 'digital volume'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 63'
            dbmin -7308
            dbmax 0
            dbvalue.0 -7308
    control.14 {
        iface MIXER
        name 'earpiece volume'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 31'
            dbmin -4350
            dbmax 300
            dbvalue.0 -4350
    control.15 {
        iface MIXER
        name 'speaker volume'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 31'
            dbmin -4800
            dbmax -150
            dbvalue.0 -4800
    control.16 {
        iface MIXER
        name 'headphone volume'
        value 44
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 63'
            dbmin -6300
            dbmax 0
            dbvalue.0 -1900
    control.17 {
        iface MIXER
        name 'MIC1_G boost stage output mixer control'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.18 {
        iface MIXER
        name 'MIC1 boost AMP gain control'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin 0
            dbmax 1400
            dbvalue.0 0
    control.19 {
        iface MIXER
        name 'MIC2 BST stage to L_R outp mixer gain'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.20 {
        iface MIXER
        name 'MIC2 boost AMP gain control'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin 0
            dbmax 1400
            dbvalue.0 0
    control.21 {
        iface MIXER
        name 'LINEINL/R to L_R output mixer gain'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.22 {
        iface MIXER
        name 'ADC input gain control'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.23 {
        iface MIXER
        name 'Phoneout gain control'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.24 {
        iface MIXER
        name 'SRC FUCTION'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.25 {
        iface MIXER
        name 'I2S HUB FUNC'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.26 {
        iface MIXER
        name 'Phoneout Mixer MIC1 boost Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.27 {
        iface MIXER
        name 'Phoneout Mixer MIC2 boost Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.28 {
        iface MIXER
        name 'Phoneout Mixer Rout_Mixer_Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.29 {
        iface MIXER
        name 'Phoneout Mixer Lout_Mixer_Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.30 {
        iface MIXER
        name 'ADCR Mux'
        value ADC
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 ADC
            item.1 DMIC
    control.31 {
        iface MIXER
        name 'ADCL Mux'
        value ADC
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 ADC
            item.1 DMIC
    control.32 {
        iface MIXER
        name 'MIC2 SRC'
        value MIC2
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 MIC3
            item.1 MIC2
    control.33 {
        iface MIXER
        name 'RADC input Mixer MIC1 boost Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.34 {
        iface MIXER
        name 'RADC input Mixer MIC2 boost Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.35 {
        iface MIXER
        name 'RADC input Mixer LINEINR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.36 {
        iface MIXER
        name 'RADC input Mixer r_output mixer Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.37 {
        iface MIXER
        name 'RADC input Mixer l_output mixer Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.38 {
        iface MIXER
        name 'RADC input Mixer PHONINN Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.39 {
        iface MIXER
        name 'RADC input Mixer PHONINN-PHONINP Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.40 {
        iface MIXER
        name 'LADC input Mixer MIC1 boost Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.41 {
        iface MIXER
        name 'LADC input Mixer MIC2 boost Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.42 {
        iface MIXER
        name 'LADC input Mixer LINEINL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.43 {
        iface MIXER
        name 'LADC input Mixer l_output mixer Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.44 {
        iface MIXER
        name 'LADC input Mixer r_output mixer Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.45 {
        iface MIXER
        name 'LADC input Mixer PHONINP Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.46 {
        iface MIXER
        name 'LADC input Mixer PHONINP-PHONINN Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.47 {
        iface MIXER
        name 'AIF3OUT Mux'
        value 'AIF2 ADC left channel'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 'AIF2 ADC left channel'
            item.1 'AIF2 ADC right channel'
    control.48 {
        iface MIXER
        name 'AIF2 ADR Mixer AIF1 DA0R Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.49 {
        iface MIXER
        name 'AIF2 ADR Mixer AIF1 DA1R Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.50 {
        iface MIXER
        name 'AIF2 ADR Mixer AIF2 DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.51 {
        iface MIXER
        name 'AIF2 ADR Mixer ADCR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.52 {
        iface MIXER
        name 'AIF2 ADL Mixer AIF1 DA0L Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.53 {
        iface MIXER
        name 'AIF2 ADL Mixer AIF1 DA1L Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.54 {
        iface MIXER
        name 'AIF2 ADL Mixer AIF2 DACR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.55 {
        iface MIXER
        name 'AIF2 ADL Mixer ADCL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.56 {
        iface MIXER
        name 'AIF2INR Mux'
        value AIF2_DACR
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_DACR
            item.1 AIF2_DACL
            item.2 SUM_AIF2DACL_AIF2DACR
            item.3 AVE_AIF2DACL_AIF2DACR
    control.57 {
        iface MIXER
        name 'AIF2INL Mux'
        value AIF2_DACL
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_DACL
            item.1 AIF2_DACR
    control.58 {
        iface MIXER
        name 'AIF2OUTR Mux'
        value AIF2_ADCR
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_ADCR
            item.1 AIF2_ADCL
            item.2 SUM_AIF2_ADCL_AIF2_ADCR
            item.3 AVE_AIF2_ADCL_AIF2_ADCR
    control.59 {
        iface MIXER
        name 'AIF2OUTL Mux'
        value AIF2_ADCL
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_ADCL
            item.1 AIF2_ADCR
    control.60 {
        iface MIXER
        name 'EAR Mux'
        value DACR
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 DACR
            item.1 DACL
            item.2 'Right Analog Mixer'
            item.3 'Left Analog Mixer'
    control.61 {
        iface MIXER
        name 'SPK_L Mux'
        value 'MIXEL Switch'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 'MIXEL Switch'
            item.1 'MIXL MIXR  Switch'
    control.62 {
        iface MIXER
        name 'SPK_R Mux'
        value 'MIXER Switch'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 'MIXER Switch'
            item.1 'MIXR MIXL Switch'
    control.63 {
        iface MIXER
        name 'HP_L Mux'
        value 'DACL HPL Switch'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 'DACL HPL Switch'
            item.1 'Left Analog Mixer HPL Switch'
    control.64 {
        iface MIXER
        name 'HP_R Mux'
        value 'DACR HPR Switch'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 'DACR HPR Switch'
            item.1 'Right Analog Mixer HPR Switch'
    control.65 {
        iface MIXER
        name 'Right Output Mixer DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.66 {
        iface MIXER
        name 'Right Output Mixer DACR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.67 {
        iface MIXER
        name 'Right Output Mixer LINEINR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.68 {
        iface MIXER
        name 'Right Output Mixer MIC2Booststage Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.69 {
        iface MIXER
        name 'Right Output Mixer MIC1Booststage Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.70 {
        iface MIXER
        name 'Right Output Mixer PHONEINN Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.71 {
        iface MIXER
        name 'Right Output Mixer PHONEINN-PHONEINP Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.72 {
        iface MIXER
        name 'Left Output Mixer DACR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.73 {
        iface MIXER
        name 'Left Output Mixer DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.74 {
        iface MIXER
        name 'Left Output Mixer LINEINL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.75 {
        iface MIXER
        name 'Left Output Mixer MIC2Booststage Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.76 {
        iface MIXER
        name 'Left Output Mixer MIC1Booststage Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.77 {
        iface MIXER
        name 'Left Output Mixer PHONEINP Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.78 {
        iface MIXER
        name 'Left Output Mixer PHONEINP-PHONEINN Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.79 {
        iface MIXER
        name 'DACR Mixer ADCR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.80 {
        iface MIXER
        name 'DACR Mixer AIF2DACR Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.81 {
        iface MIXER
        name 'DACR Mixer AIF1DA1R Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.82 {
        iface MIXER
        name 'DACR Mixer AIF1DA0R Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.83 {
        iface MIXER
        name 'DACL Mixer ADCL Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.84 {
        iface MIXER
        name 'DACL Mixer AIF2DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.85 {
        iface MIXER
        name 'DACL Mixer AIF1DA1L Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.86 {
        iface MIXER
        name 'DACL Mixer AIF1DA0L Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.87 {
        iface MIXER
        name 'AIF1 AD1R Mixer AIF2 DACR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.88 {
        iface MIXER
        name 'AIF1 AD1R Mixer ADCR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.89 {
        iface MIXER
        name 'AIF1 AD1L Mixer AIF2 DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.90 {
        iface MIXER
        name 'AIF1 AD1L Mixer ADCL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.91 {
        iface MIXER
        name 'AIF1 AD0R Mixer AIF1 DA0R Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.92 {
        iface MIXER
        name 'AIF1 AD0R Mixer AIF2 DACR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.93 {
        iface MIXER
        name 'AIF1 AD0R Mixer ADCR Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.94 {
        iface MIXER
        name 'AIF1 AD0R Mixer AIF2 DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.95 {
        iface MIXER
        name 'AIF1 AD0L Mixer AIF1 DA0L Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.96 {
        iface MIXER
        name 'AIF1 AD0L Mixer AIF2 DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.97 {
        iface MIXER
        name 'AIF1 AD0L Mixer ADCL Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.98 {
        iface MIXER
        name 'AIF1 AD0L Mixer AIF2 DACR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.99 {
        iface MIXER
        name 'AIF1IN1R Mux'
        value AIF1_DA1L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA1R
            item.1 AIF1_DA1L
            item.2 SUM_AIF1DA1L_AIF1DA1R
            item.3 AVE_AIF1DA1L_AIF1DA1R
    control.100 {
        iface MIXER
        name 'AIF1IN1L Mux'
        value AIF1_DA1L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA1L
            item.1 AIF1_DA1R
    control.101 {
        iface MIXER
        name 'AIF1IN0R Mux'
        value AIF1_DA0R
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA0R
            item.1 AIF1_DA0L
            item.2 SUM_AIF1DA0L_AIF1DA0R
            item.3 AVE_AIF1DA0L_AIF1DA0R
    control.102 {
        iface MIXER
        name 'AIF1IN0L Mux'
        value AIF1_DA0L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA0L
            item.1 AIF1_DA0R
    control.103 {
        iface MIXER
        name 'AIF1OUT1R Mux'
        value AIF1_AD1R
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD1R
            item.1 AIF1_AD1L
            item.2 SUM_AIF1ADC1L_AIF1ADC1R
            item.3 AVE_AIF1ADC1L_AIF1ADC1R
    control.104 {
        iface MIXER
        name 'AIF1OUT1L Mux'
        value AIF1_AD1L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD1L
            item.1 AIF1_AD1R
    control.105 {
        iface MIXER
        name 'AIF1OUT0R Mux'
        value AIF1_AD0R
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD0R
            item.1 AIF1_AD0L
            item.2 SUM_AIF1AD0L_AIF1AD0R
            item.3 AVE_AIF1AD0L_AIF1AD0R
    control.106 {
        iface MIXER
        name 'AIF1OUT0L Mux'
        value AIF1_AD0L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD0L
            item.1 AIF1_AD0R
    control.107 {
        iface MIXER
        name 'AIF2INR Mux VIR switch aif2inr aif3'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.108 {
        iface MIXER
        name 'AIF2INL Mux VIR switch aif2inl aif3'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.109 {
        iface MIXER
        name 'AIF2INR Mux switch aif2inr aif2'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.110 {
        iface MIXER
        name 'AIF2INL Mux switch aif2inl aif2'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.111 {
        iface MIXER
        name 'External Speaker Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.112 {
        iface MIXER
        name 'Headphone Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.113 {
        iface MIXER
        name 'Earpiece Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
state.sndhdmi {
    control.1 {
        iface MIXER
        name 'hdmi audio format Function'
        value pcm
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 null
            item.1 pcm
            item.2 AC3
            item.3 MPEG1
            item.4 MP3
            item.5 MPEG2
            item.6 AAC
            item.7 DTS
            item.8 ATRAC
            item.9 ONE_BIT_AUDIO
            item.10 DOLBY_DIGITAL_PLUS
            item.11 DTS_HD
            item.12 MAT
            item.13 WMAPRO
That is a part of the Android config so you can't copy paste that into asound.state directly, you have to manually set those in alsamixer...
Here the full file with all the audio paths Android uses for the Pine64/Pinebook:
http://pastebin.ubuntu.com/24260816/
Sad
(03-27-2017, 07:23 AM)xalius Wrote: That is a part of the Android config so you can't copy paste that into asound.state directly, you have to manually set those in alsamixer...
Hi Xalius,
I try to match all the configurations related to MIC2 but the result is the same...
I don't understand.
Here my asound.state file:
state.audiocodec {
    control.1 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.2 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.3 {
        iface MIXER
        value.0 153
        value.1 153
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -450
            dbvalue.1 -450
    control.4 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.5 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 15'
            dbmin -600
            dbmax 8400
            dbvalue.0 -600
            dbvalue.1 -600
    control.6 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 3'
            dbmin -600
            dbmax 1200
            dbvalue.0 -600
            dbvalue.1 -600
    control.7 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.8 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.9 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 15'
            dbmin -600
            dbmax 8400
            dbvalue.0 -600
            dbvalue.1 -600
    control.10 {
        iface MIXER
        name 'ADC volume'
        value.0 160
        value.1 160
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.11 {
        iface MIXER
        name 'DAC volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.12 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 15'
            dbmin -600
            dbmax 8400
            dbvalue.0 -600
            dbvalue.1 -600
    control.13 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 63'
            dbmin -7308
            dbmax 0
            dbvalue.0 -7308
    control.14 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 31'
            dbmin -4350
            dbmax 300
            dbvalue.0 -4350
    control.15 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 31'
            dbmin -4800
            dbmax -150
            dbvalue.0 -4800
    control.16 {
        iface MIXER
        value 44
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 63'
            dbmin -6300
            dbmax 0
            dbvalue.0 -1900
    control.17 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.18 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin 0
            dbmax 1400
            dbvalue.0 0
    control.19 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.20 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin 0
            dbmax 1400
            dbvalue.0 0
    control.21 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.22 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.23 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.24 {
        iface MIXER
        name 'SRC FUCTION'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.25 {
        iface MIXER
        name 'I2S HUB FUNC'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.26 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.27 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.28 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.29 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.30 {
        iface MIXER
        name 'ADCR Mux'
        value ADC
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 ADC
            item.1 DMIC
    control.31 {
        iface MIXER
        name 'ADCL Mux'
        value ADC
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 ADC
            item.1 DMIC
    control.32 {
        iface MIXER
        name 'MIC2 SRC'
        value MIC2
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 MIC3
            item.1 MIC2
    control.33 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.34 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.35 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.36 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.37 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.38 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.39 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.40 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.41 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.42 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.43 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.44 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.45 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.46 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.47 {
        iface MIXER
        name 'AIF3OUT Mux'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
    control.48 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.49 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.50 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.51 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.52 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.53 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.54 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.55 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.56 {
        iface MIXER
        name 'AIF2INR Mux'
        value AIF2_DACR
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_DACR
            item.1 AIF2_DACL
    control.57 {
        iface MIXER
        name 'AIF2INL Mux'
        value AIF2_DACL
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_DACL
            item.1 AIF2_DACR
    control.58 {
        iface MIXER
        name 'AIF2OUTR Mux'
        value AIF2_ADCR
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_ADCR
            item.1 AIF2_ADCL
    control.59 {
        iface MIXER
        name 'AIF2OUTL Mux'
        value AIF2_ADCL
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_ADCL
            item.1 AIF2_ADCR
    control.60 {
        iface MIXER
        name 'EAR Mux'
        value DACR
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 DACR
            item.1 DACL
    control.61 {
        iface MIXER
        name 'SPK_L Mux'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
    control.62 {
        iface MIXER
        name 'SPK_R Mux'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
    control.63 {
        iface MIXER
        name 'HP_L Mux'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
    control.64 {
        iface MIXER
        name 'HP_R Mux'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
    control.65 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.66 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.67 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.68 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.69 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.70 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.71 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.72 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.73 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.74 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.75 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.76 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.77 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.78 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.79 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.80 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.81 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.82 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.83 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.84 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.85 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.86 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.87 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.88 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.89 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.90 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.91 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.92 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.93 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.94 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.95 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.96 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.97 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.98 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.99 {
        iface MIXER
        name 'AIF1IN1R Mux'
        value AIF1_DA1L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA1R
            item.1 AIF1_DA1L
    control.100 {
        iface MIXER
        name 'AIF1IN1L Mux'
        value AIF1_DA1L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA1L
            item.1 AIF1_DA1R
    control.101 {
        iface MIXER
        name 'AIF1IN0R Mux'
        value AIF1_DA0R
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA0R
            item.1 AIF1_DA0L
    control.102 {
        iface MIXER
        name 'AIF1IN0L Mux'
        value AIF1_DA0L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA0L
            item.1 AIF1_DA0R
    control.103 {
        iface MIXER
        value AIF1_AD1R
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD1R
            item.1 AIF1_AD1L
    control.104 {
        iface MIXER
        value AIF1_AD1L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD1L
            item.1 AIF1_AD1R
    control.105 {
        iface MIXER
        value AIF1_AD0R
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD0R
            item.1 AIF1_AD0L
    control.106 {
        iface MIXER
        value AIF1_AD0L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD0L
            item.1 AIF1_AD0R
    control.107 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.108 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.109 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.110 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.111 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.112 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.113 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
state.sndhdmi {
    control.1 {
        iface MIXER
        value pcm
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 null
            item.1 pcm
            item.2 AC3
            item.3 MPEG1
            item.4 MP3
            item.5 MPEG2
            item.6 AAC
            item.7 DTS
            item.8 ATRAC
            item.11 DTS_HD
            item.12 MAT
            item.13 WMAPRO
Can you see any mismatch? Huh Huh Huh Huh Huh Huh Huh Huh Huh Huh
How do you check if your mic is working?
(03-27-2017, 09:08 AM)xalius Wrote: How do you check if your mic is working?
I check it on my Ubuntu Laptop and it works fine Sad
No I mean what software do you use on the Pine with your mic? Do you use ALSA utilitties or something else?
(03-27-2017, 09:25 AM)xalius Wrote: No I mean what software do you use on the Pine with your mic? Do you use ALSA utilitties or something else?
I'm trying to record with these two commands:
  • arecord -f S16_LE -D hw:1,0 -V stereo "recording.wav"
  • pacat --record -d alsa_output.platform-sound.6.analog-stereo.monitor | sox -t raw -r 44100 -L -e signed-integer -S -b 16 -c 2 - "recording.wav" (these record the signal in output channel)
  • pacat --record -d alsa_input.platform-sound.6.analog-stereo | sox -t raw -r 44100 -L -e signed-integer -S -b 16 -c 2 - "recording.wav"
Aren't these correct?
That should be ok, I would use arecord too for testing, make sure you have the correct device...
  +LTS/SOPINE Audio Jack Pinout Little_Johnny 0 5,887 12-29-2019, 08:44 AM
Last Post: Little_Johnny
  Pine64 (analog) Audio Jack Output w/ Kernel 4.19 ecolezen 0 6,067 01-24-2019, 07:00 AM
Last Post: ecolezen
  Sound quality from audio jack devanl 0 6,115 10-11-2017, 10:39 PM
Last Post: devanl
  Packet loss on lan port Hiren 4 11,215 09-06-2016, 08:18 AM
Last Post: Hiren
