Calling an external command in Python
How can I call an external command (as if I'd typed it at the Unix shell or Windows command prompt) from within a Python script?
(01-30-2017, 09:31 AM)douglassirkshaun Wrote: How can I call an external command (as if I'd typed it at the Unix shell or Windows command prompt) from within a Python script?
The sys module and the os module will be helpful for you.
from sys import *
from os import *
or,  just import the components you need.
http://www.python-course.eu/sys_module.php
http://www.python-course.eu/os_module_shell.php
Read the two links posted above.  Specifically the os module will allow you to make shell commands from python scripts.  The sys module will help you get input args (argv) and to get information about the system into your python scripts.
  [PINE A64 2GB Kickstarter]How to boot android from external SSD v1n1c1uS 1 4,979 01-15-2018, 11:05 PM
  Connecting external DVDRW drive via USB to Pine64 galbez 4 9,218 10-12-2017, 12:35 PM
Last Post: Luke
