REMix OS Boots and then blank Screen
I've been trying to get REMix OS to work for me, but it seems I have 2 issues:
1) I cannot enter my google credentials
2) If I wait a few minutes the screen goes blank and cannot do anything.
Any suggestions?
Sent from my iPad using Tapatalk
(01-15-2017, 09:55 AM)Michaelrowe01 Wrote: I've been trying to get REMix OS to work for me, but it seems I have 2 issues:
Any suggestions?
I just release new build and please try out whether you still encounter same issue.
Ssame thing happens to me on latest Remix OS, when Pine64 is charged from:
* TV (my TV has a USB port for external HDD)
* Router (same as above)
* Computer
However, it works fine when connected to a charger.
Could this be due to a media connection setting?
Any suggestions?
Seems to be working fine for me now... thanks!
The issue is still present for me.
Booted the Pine using a Ubuntu OS (http://forum.pine64.org/showthread.php?tid=376). It works there.
Still, it might be an Amperage issue - it might not get enough juice from these devices to render the UI.
@tllim: what should I try next?
(01-24-2017, 05:09 AM)greig Wrote: The issue is still present for me.
Same issue. I've tried several different chargers (even juicy ones).
  Are you using the MicroUSB port? They are notoriously flakey. I kept having problems until I hooked power directly to the bus pins. The USB power out from your TV is very likely not enough amp's to power the Pine.
  sourround sound - Remix MrSarkasmus 0 5,189 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 64,409 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 7,080 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 253,031 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 7,607 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 7,385 05-29-2017, 02:42 AM
  Stuck at Remix OS logo leongzhi 9 33,918 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,511 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 6,680 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
  No microphone input in Remix xtcrefugee 3 15,139 08-19-2016, 06:24 PM
Last Post: jkmooney
