Microphone options
Hello all,
Bought the plus version a while back and now found a good use for the LCD, playbox and of course a Pine 64.  Was wondering if there are any add on microphone options?  Ideally something that will fit in the playbox.  I'm not opposed to doing a bit of drilling I need too.  I have a Dremel and not afraid to use it!
I did find this for the Adafruit, would this work?
https://www.amazon.com/Adafruit-Electret...microphone
Cheers!
Paul
Any luck so frar?
(01-15-2017, 07:30 AM)Israeldelamo Wrote: Any luck so frar?
You can look at the schematic and tap to the mic 2 wiring.
  Inexpensive USB Microphone Option Ron Piggott 4 11,041 07-28-2016, 10:28 AM
Last Post: moondark
