Configuring static IP
Hello!
I am trying to assign static IPs to two pines and be able for them to ping each other(for future ssh).
I have edited /etc/network/interfaces:
interfaces(5) file used by ifup(8) and ifdown(8) # Include files from /etc/network/interfaces.d: # source-directory /etc/network/interfaces.d # commented out, so it doesnt conflict with this config # Disable wlan1 by default (8723bs has two intefaces) iface wlan1 inet manual auto eth0 iface eth0 inet static address 192.168.1.100 netmask 255.255.255.0 network 192.168.1.0 broadcast 192.168.1.255 gateway 192.168.1.1 dns-nameservers 4.2.2.1 4.2.2.2 8.8.8.8
similarly the second one with the IP: 192.168.1.101, left everything else the same.
I also set managed=true /etc/NetworkManager/NetworkManager.conf so it uses the data from /etc/network/interfaces
[main] plugins=ifupdown,keyfile,ofono dns=dnsmasq [ifupdown] managed=true
After a restart I can see in the network manager that both of them are corretly configured, but if I try to ping them with(from 192.168.1.101):
ping 192.168.1.100
it doesnt work.
but if I try to ping the address of my switch: 192.168.1.1, it works on both of them.
The switch in configured with the same gateway and IP: 192.168.1.1
I used longsleeps 10160528 desktop build.
I also cant go on the internet, which is connected to the switch. But between them is a router. Do I have to find out the IP of the router and set it the gateway address of the switch?
I tried using diffrent addresses for the switch(like 192.168.1.2) and use this as a gateway address in /etc/network/interfaces, but still nothing.
Any suggestions on how to make this work?
Also keep in mind, that I am a linux beginner and never did any real networking, so if you can, answer with detailed explanations and forgive my noobism.
Everything happens on purpose by accident.
The first thing to check is that they each have a unique mac address.
... communication actually happens between mac addresses,  with adress resolution protocol ( ARP ) going on in the middle. It the mac addresses are the 'same' then the machines cannot communicate correctly.
This is a problem on the pine, for some of the gnu+linux images, because each machine ends up with the same mac address.   (rats)
cat  /boot/uEnv.txt
... for each machine;  what is the mac addy ?
Yes, you nailed it. It didnt work, because each mac address was the same.
I downloaded macchanger, changed the mac-s, tried pinging and it worked.
Thanks for the help!
If I set the switch gateway to anything else, then the internet also works(gateway on pine set to switch address).
Can anyone help me configure my static IP for Pine.
I have ASUS router behind ISP modem and I connect to it on 192.168.2.1
Now I have setup static IP on pine but I'm doing something wrong!
(lack of knowledge)
interfaces(5) file used by ifup(8) and ifdown(8) # Include files from /etc/network/interfaces.d: # source-directory /etc/network/interfaces.d # commented out, so it doesnt conflict with this config # Disable wlan1 by default (8723bs has two intefaces) iface wlan1 inet manual auto eth0 iface eth0 inet static address 192.168.2.172 network 192.168.2.0 netmask 255.255.255.0 gateway 192.168.2.1
ipconfig:
[Image: 8084e33bfd.png]
  possible to set a static IP using uEnv.txt? cplr 2 7,766 05-13-2016, 06:57 AM
Last Post: RanTalbott
