Hi guys!
well there is some thins that i think are "Most Have" to this board
GPIO IDE ( for linux )
like the one that the community are developing with C and Python ported for RPi
so examples about UART, I2C PWM , Analog In , SPI and general I/O
but cleaner and easier
good job for those that are working on that BTW
GPIO Example codes for Android
i'm planing to use one of my pines for Android Only and wanted to use the GPIO ports from Android apps ( that I'll create ) to run servos and some robotic stuff
so having example codes would be nice
Android and Linux Image's Build Guides
guides to be able to compile our own Images/Roms and imrove the developents like cyanogenmod , AOSP and many more
in linux, how about the port of Kali linux
and many other Linux distributions
Kernel Customization Guides
Well the name says everything -- to be able to add kernel modules or even upgrade the kernel version
POT MODULES
such as GPS, LTE, Gyroscope, Barometer, DAC ,etc
if we can get the IDE and examples for Android the implementation of already available modules can be easier :
and of course guides about the implementation with pine :
well those are some of the things that for me are Must have and if u have some more ideas pls post them
and comment about what do you think about this
and many other Linux distributions Kernel Customization Guides
POT MODULES
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
Installed:
Netbeans 8.1
