Howto use MAC address as printed on the label on the back
The BSP Linux Kernel does automatically generate a locally administered MAC address for the Ethernet (eth0) interface.
Some networks might not be able to handle those correctly. The recommended solution is to manually set the MAC address to the one which is printed on the back of the Pine64 by adding it to /boot/uEnv.txt with a line like ethaddr=xx:xx:xx:xx:xx:xx.
The MAC address is the lower number on the barcode label on the back of your Pine board. Start from the left and add a colon every two chars. So far they all seem to start with 00:06:dc making this the vendor prefix.
It came to my attention that there are Pine64 boards which only have a single barcode/number on the back. Thats the serial number and not the MAC address. If thats the case for you you are lost for now. Maybe Pine64 can give some details how to derive the MAC address from the serial number (if possible).
If you want to test your Network speed properly see http://forum.pine64.org/showthread.php?tid=2052
... moved this thread to the Ethernet sub-forum, and made it 'sticky'.
  Howto test and tune Gigabit Networking (1000M) longsleep 16 47,042 05-18-2022, 02:07 PM
Last Post: moriel5
  Rock64: MAC Address is NOT Unique! PDXpi 3 9,595 02-01-2021, 12:12 AM
Last Post: PDXpi
  The Mac Address Would Not Change on Debian, nor Gentoo MarkHaysHarris777 5 14,496 03-27-2017, 12:57 PM
Last Post: grobbs
Question no permanent MAC address? need it to give Pine64 a reserved IP. faddah 14 37,787 08-24-2016, 03:25 PM
Last Post: MarkHaysHarris777
