06-22-2016, 06:17 PM
The camera module is working on Linux 3.10.102.
Have a look here: http://forum.armbian.com/index.php/topic...or-pine64/
Camera is working on Linux
06-22-2016, 06:44 PM
kewl including guvcview into the next debian image release (Mate and XFCE)
If you like my work be sure to check out my site or wish to donate to the cause
Cheers ![]()
PKernel 3.10.102 longsleep, get
My modified guvcview github.com/avafinger
06-22-2016, 10:47 PM
@lex, this?
https://github.com/avafinger/guvcview updated to include pine64 yet? btw, thanks. now i just need a camera.
06-22-2016, 11:38 PM
nice... now i just need my camera to get here...
06-23-2016, 10:44 AM
(06-22-2016, 10:47 PM)dkryder Wrote: @lex, this? Yes, updated to compile on pine64+. BTW, if someone has hm5065 module should update to 3.10.102 and compile DTB and give it a try, maybe this can work (only if the module works on Android).
06-23-2016, 11:01 AM
Nice! I should order a camera module, but I still got two USB cams sitting around...
Come have a chat in the Pine IRC channel >>
On (up to date) Ubuntu I get:
Code: $ guvcview
GUVCVIEW: version 2.0.2
GUVCVIEW: couldn't open /home/ubuntu/.config/guvcview2/video0 for read: No such file or directory
V4L2_CORE: ERROR opening V4L interface: No such file or directory
(process:8056): Gtk-WARNING **: Locale not supported by C library.
Using the fallback 'C' locale.
Gtk-Message: GtkDialog mapped without a transient parent. This is discouraged.Code: $ uname -a
Linux localhost.localdomain 3.10.102-0-pine64-longsleep #7 SMP PREEMPT Fri Jun 17 21:30:48 CEST 2016 aarch64 aarch64 aarch64 GNU/LinuxThere is no /dev/video* and no /dev/v4l* How do I fix this or go about finding the cause?
06-28-2016, 04:58 PM
STEP 1
sudo -i resize_rootfs.sh reboot STEP 2 (After Reboot) sudo -i pine64_update_uboot.sh pine64_update_kernel.sh reboot STEP 3 sudo -i apt-get -f install apt-get install v4l-utils
Cheers ![]()
06-28-2016, 11:31 PM
That doesn't help for me. I'm running Debian, uboot and kernel are updated to newest. It seems that system just doesn't see the camera at all. There's no /dev/video and dmesg shows v4l-modules loaded with "device as (null)". Full dmesg here.
There have been different information about the required kernel module. Some say it's hm5065, others ov6650 or s5k4ec. I've tried them all and several others with modprobe with no luck. At the moment my lsmod says Code: root@pine:~# lsmod
Module Size Used by
ov6650 17419 0
soc_camera 23007 1 ov6650
soc_mediabus 12729 1 soc_camera
videobuf_core 21858 1 soc_camera
hm5065 25664 0
s5k4ec 33771 0
vfe_v4l2 747618 0
vfe_io 34085 3 vfe_v4l2,hm5065,s5k4ec
mali 199851 0
ir_lirc_codec 12756 0
lirc_dev 17032 1 ir_lirc_codec
ir_jvc_decoder 12487 0
ir_sanyo_decoder 12491 0
ir_sony_decoder 12489 0
ir_rc6_decoder 12520 0
ir_nec_decoder 12487 0
ir_rc5_decoder 12487 0
ir_mce_kbd_decoder 12628 0
ss 33083 0
videobuf2_dma_contig 17668 1 vfe_v4l2
videobuf2_memops 12546 1 videobuf2_dma_contig
sunxi_ir_rx 12902 0
videobuf2_core 30952 2 vfe_v4l2,soc_camera
cedar_ve 17368 0
8723bs 1365012 0
cfg80211 374207 1 8723bsCould someone with the soc camera working post their lsmod? Or dmesg? I have no idea where to continue now. |
| Anyone get the camera to work yet? | Havensal | 16 | 41,205 |
09-13-2022, 03:31 AM Last Post: harryaxe31 |
| camera port details? | gourmand007 | 6 | 21,770 |
03-07-2021, 05:29 PM Last Post: DippingMyToesIn |
| About the camera | robopo | 11 | 31,740 |
03-06-2021, 12:28 AM Last Post: DippingMyToesIn |
| CSI / Camera Module Compatibility? | vade | 8 | 25,620 |
04-03-2020, 05:39 AM Last Post: Ellesar Dragon |
| 13MP Camera cable extension | saviod | 2 | 8,874 |
06-21-2019, 06:05 AM Last Post: saviod |
| Camera | Sasank | 15 | 40,128 |
12-13-2018, 09:08 PM Last Post: Mutani |
| Himax 5 Megapixel Camera Module cannot fit into 7″ LCD Touch Screen Panel | themyshop | 3 | 11,510 |
05-10-2018, 04:28 PM Last Post: tllim |
| Webcam vs camera module on pine64+ | fkpkot | 4 | 15,382 |
02-27-2017, 03:57 PM Last Post: MarkHaysHarris777 |
| camera module and lcd integration | jodybrown99 | 5 | 15,273 |
10-11-2016, 11:35 AM Last Post: hikaricore |
