Rii mini 4 keyboard and touchpad work over Bluetooth
Why to be smart if Bluetooth works?
I thought that the Rii mini 4 with 2.4 Ghz dongle would be the ultimate solution to solve the Pinephone keyboard problem. After a sleepless night in which I tested 6 cheap Aliexpress docks in all configuration with usb keyboard and mouse, none of the worked. Some time ago, one of them worked with usb keyboard and mouse, but I could not reproduce it.  I thought a Rii mini 4 with 2.4 Ghz dongle would eventually the solution for the Pinephone keyboard problem together with the docking sation:
https://forum.pine64.org/showthread.php?tid=19350
But in the morning I decided not to buy any further Pinephone accessoires for a Pinephone I never use and put on the screed and take it down again for some tests.
In the afternoon, I thought,  why not to try the Rii 4 over Bluetooth? Reports of Zebulon Walton about a Bluetooth mini keyboard where horrible:
https://forum.pine64.org/showthread.php?...316&page=2
Now i paired the Rii 4 mini over Bluetooth to my Pinephone with postmarketOS. There where no disconnection issues during 3 min tests as where reported with other Bluetooth keyboards:
https://forum.pine64.org/showthread.php?tid=13835
Keys, touchpad and scrollweel worked. One user reported to have issues with connecting a Bluetooth keyboard and mouse at the same time. Only one device worked, either keyboard and mouse.  Other reported that Bluetooth keyboard and mouse work with Logitech devices:
https://forum.pine64.org/showthread.php?...316&page=3
But Logitech has not mini keyboards. The Rii mini 4 is a mini keyboard with dual mode BLE and 2.4 Ghz dongle. I did not get to work the 2.4 Ghz dongle, but the keyboard with touchpad.
The Rii 4 over Bluetooth is the best experience for a Pinephone keyboard for me personally to this date. It is available and worked for 3 min. reliably. And it has also a layout with many keys, similar to the Pinephone keyboard which makes it  a great device. The keyboard is not much bigger than the Pinephone, and fit’s in a pocket.
There is also the EASYTONE Mini Wireless Keyboard which I found worked with the USB connection on my Mobian Bookworm 3GB pinephone.
But I think I may get the Rii if it is narrower - I need a keyboard less than 75mm wide to try to stuff it in my Gamesir Nova Lite Phone holder (maybe with some added foam padding), so I can type while walking around!
OK here is a keyboard -  phone holder combination that allows you to clamp the keyboard in the custom bracket meant for the game controller, while the Pinephone is securely clamped in the spring-loaded bracket:
- 8Bitdo Mobile Clip for SN30 Pro Bluetooth Controller
-  Rii Mini Keyboard,Wireless Keyboard with Touhpad,Keyboard Remote for Smart TV,Android TV Box,PC,Laptop,Windows,Mac
Note the keyboard has to be fitted in at an angle - it will snap securely into place, as long as the phone bracket is swivelled and locked in at the right angle.
The weight balance is a little phone heavy, but it does turn your pinephone into a pda with attached keyboard!
  Pinephone (Pro) Keyboard Case for sale manubert 8 18,460 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,597 01-12-2026, 06:09 PM
Last Post: ragele
  keyboard case charging but not typing new2pinephone 19 25,614 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,144 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 21,849 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  How to get the Rii 4 with 2.4 Ghz get to work with the PP Peter Gamma 1 3,104 07-18-2024, 10:48 AM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 4,989 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 2,944 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 4,633 06-29-2024, 09:36 PM
  Bluetooth keyboard with trackpad Zebulon Walton 11 22,571 06-29-2024, 04:09 AM
