Booting Issues
#21
I had the screen flickering instead of booting problem.
The update was probably done a couple of days ago, max 15.
I booted the Pine Note on a plane to see it has become a paperweight Wink And arrived at the destination without reading.
What worked for me:
1. Creating a HotSpot with the same name as home network
2. SSH-ing into pinenote
3.
sudo dpkg -i /var/cache/apt/archives/mutter-common_47.3-2_all.deb
This was _not_ downloaded.
Some debugging for the wise, what didn't work:
PHP Code:
user@pinenote:~$ sudo apt full-upgrade
[sudo] password for user:
The following packages were automatically installed and are no longer required:
  cheese                        libabsl20230802      libglapi-mesa            libnsl2                libraqm0                    lp-solve                  python3.12
  cheese
-common                  libcamera0.3          libgnome-menu-3-0        libopenh264-7          libruby3.1t64                network-manager-gnome      python3.12-minimal
  coinor
-libcoinmp1v5            libcheese-gtk25      libicu72                  libpaper1              libtag1v5                    python3-autocommand        ruby3.1
  eog                            libcheese8            libjxl0.10                libpoppler
-cpp1        libtag1v5-vanilla            python3-inflect            tracker
  gir1.2
-gmenu-3.0              libclutter-gst-3.0-0  libjxl0.9                libpoppler140          libunwind8                  python3-jaraco.context    tracker-miner-fs
  gir1.2
-gtop-2.0                libconfig++9v5        libldap-2.5-0            libpoppler145          libutempter0                python3-jaraco.functools
  gnome
-shell-extensions-common  libdirectfb-1.7-7t64  libmagickcore-6.q16-7t64  libpython3.12-minimal  libwebrtc-audio-processing1  python3-more-itertools
  gnome
-video-effects            libdrm-radeon1        libmagickwand-6.q16-7t64  libpython3.12-stdlib  libx265-209                  python3-pkg-resources
  gstreamer1.0
-clutter-3.0      libflac12t64          libmbedcrypto7t64        libpython3.12t64      libxcb-dri2-0                python3-typeguard
  imagemagick
-6.q16              libfuse3-3            libmsgraph-0-1            libqpdf29t64          libxnnpack0                  python3-typing-extensions
Use 'sudo apt autoremove' to remove them.
Not upgrading:
  gnome  gnome-core  mutter-common-bin  xdg-desktop-portal-gnome
and not even
PHP Code:
user@pinenote:~$ sudo apt upgrade mutter-common-bin
Calculating upgrade
... Error!
Some packages could not be installed
. This may mean that you have
requested an impossible situation
or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
Unsatisfied dependencies:
gir1.2-mutter-15 : Depends: libmutter-15-0 (= 47.4-1) but it is not going to be installed
gnome
-shell : Depends: libmutter-15-0 (>= 47.0) but it is not going to be installed
              Recommends
: bolt but it is not going to be installed
              Recommends
: gnome-browser-connector but it is not going to be installed
              Recommends
: gnome-remote-desktop but it is not going to be installed
              Recommends
: ibus but it is not going to be installed
              Recommends
: iio-sensor-proxy but it is not going to be installed
              Recommends
: switcheroo-control but it is not going to be installed
The above errors sound as if mutter should NOT be updated, but it did? Anyway, see my number 3. above, for now..
(09-04-2025, 12:52 PM)vlagged Wrote: I had the screen flickering instead of booting problem.
What worked for me:
3.
PHP Code:
  cheese
  coinor
  gir1.2
  gir1.2
  gnome
  gnome
  gstreamer1.0
  imagemagick
Not upgrading:
and not even
PHP Code:
Calculating upgrade
... Error!
gnome
              Recommends
              Recommends
              Recommends
              Recommends
              Recommends
              Recommends
Hi vlagged,
I'm not as tech savy as the average user on this forum. Could you please guide me on how to follow your steps, especially 1&2?
Kind regards
The solution to downgrade  mutter-common to 47.4-1_all helped.
However, probably it helps someone to read my booting errors.
when useing the(currently) latest stable 48.4-2 package, i get
 "[    2.301859] rockchip-drm display-subsystem: [drm:rockchip_drm_platform_probe [rockchipdrm]] *ERROR* No available vop found for display-subsystem."
I'll just dump the whole bootup log as well. Maybe it helps someone Smile
DDR Version V1.10 20200218_resume
ln
start i2c rd
suspend_info:0x0, flag:0x20
LP4 MR12:0x5d,MR14:0x5d
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=4096MB
change to: 324MHz
PWRCTL:0x40,stat:0x303
minca:0x80,ck:0x80,ab:0x80,0x80, min_ck:0x0
PWRCTL:0x0,stat:0x1
get tdqqs2dq:361 ps
change to: 528MHz
vref_ca:00000071
minca:0x7b,ck:0x80,ab:0x80,0x80, min_ck:0x5
PWRCTL:0x0,stat:0x1
change to: 780MHz
vref_ca:00000071
minca:0x77,ck:0x80,ab:0x80,0x80, min_ck:0x9
PWRCTL:0x0,stat:0x1
change to: 1056MHz(final freq)
vref_ca:00000071
PWRCTL:0x0,stat:0x1
osreg:0x10010201,0x20000021
out
U-Boot SPL board init
U-Boot SPL 2017.09-gaaca6ffec1-211203 #zzz (Dec 03 2021 - 18:42:16)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC error: The cmd index is 1, ret is -110
Card did not respond to voltage select!
mmc_init: -95, time 10
spl: mmc init failed with error: -95
Trying to boot from MMC1
No misc partition
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(91d912f568...) + OK
## Checking uboot 0x00a00000 ... sha256(87e1e455fd...) + OK
## Checking fdt 0x00b2a2e0 ... sha256(a75758ff17...) + OK
## Checking atf-2 0x00069000 ... sha256(d51631cf88...) + OK
## Checking atf-3 0xfdcd0000 ... sha256(3c902b0442...) + OK
## Checking atf-4 0xfdcc9000 ... sha256(5f1580bb97...) + OK
## Checking atf-5 0x00067000 ... sha256(36cebbc60c...) + OK
## Checking optee 0x08400000 ... sha256(4fcbcd3870...) + OK
Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000)
Total: 233.739 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-210-g4af361e4c:zwx
NOTICE:  BL31: Built : 15:35:14, Jun  9 2022
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    pmu v1 is valid
INFO:    dfs DDR fsp_param[0].freq_mhz= 1056MHz
INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    Feature: ultra suspend
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-723-gdcfdd61d0 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Wed Jun  7 09:43:57 CST 2023 aarch64
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0xa00000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-ge0ec1df #runner (Oct 25 2024 - 09:52:07 +0000)
Model: Pine64 RK3566 Quartz64 Board PineNote modifications 4
PreSerial: 2, raw, 0xfe660000
DRAM:  3.7 GiB
Sysmem: init
Relocation Offset: ed2fd000, fdt: eb9f6fd8
dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
No misc partition
boot mode: None
FIT: No boot partition
No resource partition
Failed to load DTB
Failed to get kernel dtb, ret=-19
I2c0 speed: 100000Hz
vsel-gpios- not found! Error: -2
vdd_cpu init 900000 uV
PMIC:  RK8170 (on=0x80, off=0x08)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vcc_3v3 init 3300000 uV
vcca1v8_pmu init 1800000 uV
vccio_acodec init 3300000 uV
vcc3v3_pmu init 3300000 uV
vcc_1v8 init 1800000 uV
io-domain: OK
** Unable to use mmc 0:4 for loading the env **
Using default environment
osd_eink_probe start
I2c5 speed: 100000Hz
cyttsp5ub_probe start
cyttsp5_deassert_int returned: 0 0
launch app got size: 0 (expected 0)
Requesting HID descriptor
get hid descriptor got size: 32 (expected 32)
Request done
get sysinfo start
get sysinfo got size: 51 (expected 51)
get sysinfo end
Setting up the stdio support
enumerating keys:
KEY[0] = (322/672) (50/400) -> 103
KEY[1] = (322/672) (500/904) -> 28
KEY[2] = (322/672) (1004/1354) -> 108
done
Stdio setup complete
cyttsp5_deassert_int returned: 2 0
enabled
cyttsp5ub_probe finished
osd_eink_probe end
uc_key: rk8xx_pwr
adc_probe
uc_key: volume up
Enable charge animation display
Exit charge: due to charger offline
I2c3 speed: 100000Hz
detected device with ID=66 (TPS65186r1p2)
rev_id=66
Eink: use pmic tps65185@68
eink update bootargs: ebc_pmic.vcom=1480
rkf: check format failed
rkf: failed to check RKF file format
[lut]: failed to input RKF waveform
[lut]: PVI waveform
ebc-dev is probed success!
Transmit uboot logo addr(0x116cb000) to kernel
Transmit kernel logo addr(0x10b82000) to kernel
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 816000 KHz
  dpll 528000 KHz
  gpll 1188000 KHz
  cpll 1000000 KHz
  npll 1200000 KHz
  vpll 24000 KHz
  hpll 24000 KHz
  ppll 200000 KHz
  armclk 816000 KHz
  aclk_bus 150000 KHz
  pclk_bus 100000 KHz
  aclk_top_high 300000 KHz
  aclk_top_low 200000 KHz
  hclk_top 150000 KHz
  pclk_top 100000 KHz
  aclk_perimid 300000 KHz
  hclk_perimid 150000 KHz
  pclk_pmu 100000 KHz
Net:   No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
  *** U-Boot Boot Menu ***  Press UP/DOWN to move, ENTER to select     Search for extlinux.conf on all partitions     Boot OS1 (part 5)     Boot OS2 (part 6)     U-Boot console  Hit any key to stop autoboot: 15 14 13 12 11 10  9   *** U-Boot Boot Menu ***  Press UP/DOWN to move, ENTER to select     Search for extlinux.conf on all partitions     Boot OS1 (part 5)     Boot OS2 (part 6)     U-Boot consolelogo[0x2] is already loaded, just return!
Retrieving file: /boot/extlinux/extlinux.conf
2647 bytes read in 133 ms (18.6 KiB/s)
U-Boot menu
  *** U-Boot Boot Menu ***  Press UP/DOWN to move, ENTER to select1:    Debian GNU/Linux trixie/sid 6.12.0-rc2-pinenote-202410092341-00187-g5392aa8e3808
2:    Debian GNU/Linux trixie/sid 6.12.0-rc2-pinenote-202410092341-00187-g5392aa8e3808 (rescue target)
3:    Debian GNU/Linux trixie/sid 6.3.10-pinenote-202308011945-ge6603de5834c
4:    Debian GNU/Linux trixie/sid 6.3.10-pinenote-202308011945-ge6603de5834c (rescue target)
Enter choice: 1:    Debian GNU/Linux trixie/sid 6.12.0-rc2-pinenote-202410092341-00187-g5392aa8e3808
Retrieving file: /boot/initrd.img-6.12.0-rc2-pinenote-202410092341-00187-g5392aa8e3808
24379112 bytes read in 243 ms (95.7 MiB/s)
Retrieving file: /boot/vmlinuz-6.12.0-rc2-pinenote-202410092341-00187-g5392aa8e3808
23321088 bytes read in 235 ms (94.6 MiB/s)
append: root=/dev/mmcblk0p5 ignore_loglevel rw rootwait earlycon console=tty0 console=ttyS2,1500000n8 fw_devlink=off quiet loglevel=3 systemd.show_status=auto rd.udev.log_level=3 splash plymouth.ignore-serial-consoles vt.global_cursor_default=0
Retrieving file: /usr/lib/linux-image-6.12.0-rc2-pinenote-202410092341-00187-g5392aa8e3808/rockchip/rk3566-pinenote-v1.2.dtb
61927 bytes read in 349 ms (172.9 KiB/s)
Fdt Ramdisk skip relocation
## Flattened Device Tree blob at 0x0a100000
   Booting using the fdt blob at 0x0a100000
   Using Device Tree in place at 000000000a100000, end 000000000a1121e6
can't found rockchip,drm-logo, use rockchip,fb-logo
WARNING: could not set reg FDT_ERR_BADOFFSET.
failed to reserve fb-loader-logo memory
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x09400000 - 0xf0000000 (size: 0xe6c00000)
Total: 20916.704 ms
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 6.12.0-rc2-pinenote-202410092341-00187-g5392aa8e3808 (mweigand@orangepi5plus) (aarch64-linux-gnu-gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #3 SMP Wed Oct  9 23:56:35 CST 2024
[    0.000000] Machine model: Pine64 PineNote v1.2
[    0.000000] printk: debug: ignoring loglevel setting.
[    0.000000] earlycon: uart0 at MMIO32 0x00000000fe660000 (options '1500000n8')
[    0.000000] printk: legacy bootconsole [uart0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000083fffff]
[    0.000000]   node   0: [mem 0x0000000009400000-0x00000000efffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
[    0.000000] cma: Reserved 16 MiB at 0x00000000eaa00000 on node -1
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 30 pages/cpu s83736 r8192 d30952 u122880
[    0.000000] pcpu-alloc: s83736 r8192 d30952 u122880 alloc=30*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: root=/dev/mmcblk0p5 ignore_loglevel rw rootwait earlycon console=tty0 console=ttyS2,1500000n8 fw_devlink=off quiet loglevel=3 systemd.show_status=auto rd.udev.log_level=3 splash plymouth.ignore-serial-consoles vt.global_cursor_default=0
[    0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 978432
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 3MB
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: SWIOTLB bounce buffer size roundup to 4MB
[    0.000000] software IO TLB: mapped [mem 0x00000000ea000000-0x00000000ea400000] (4MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 39717 entries in 156 pages
[    0.000000] ftrace: allocated 156 pages with 4 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]     Rude variant of Tasks RCU enabled.
[    0.000000]     Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 320 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: MBI range [296:319]
[    0.000000] GICv3: Using MBI frame 0x00000000fd410000
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001716] Console: colour dummy device 80x25
[    0.002168] printk: legacy console [tty0] enabled
[    0.003298] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[    0.004327] pid_max: default: 32768 minimum: 301
[    0.005002] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005786] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.015057] rcu: Hierarchical SRCU implementation.
[    0.015552] rcu:     Max phase no-delay instances is 400.
[    0.016436] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.017738] EFI services will not be available.
[    0.018597] smp: Bringing up secondary CPUs ...
In n
n to
In n/aw l
In nIdsor
[    0.021608] Detected VIPT I-cache on CPU1
[    0.021718] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.021776] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.026705] Detected VIPT I-cache on CPU2
[    0.026805] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.026849] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.031777] Detected VIPT I-cache on CPU3
[    0.031869] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.031911] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.032083] smp: Brought up 1 node, 4 CPUs
[    0.037673] SMP: Total of 4 processors activated.
[    0.038136] CPU: All CPU(s) started at EL2
[    0.038540] CPU features: detected: 32-bit EL0 Support
[    0.039059] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.039897] CPU features: detected: Common not Private translations
[    0.040522] CPU features: detected: CRC32 instructions
[    0.041030] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.041607] CPU features: detected: LSE atomic instructions
[    0.042155] CPU features: detected: Privileged Access Never
[    0.042712] CPU features: detected: RAS Extension Support
[    0.043245] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.044020] alternatives: applying system-wide alternatives
[    0.049487] Memory: 3763512K/3913728K available (11392K kernel code, 2422K rwdata, 4128K rodata, 4736K init, 510K bss, 128456K reserved, 16384K cma-reserved)
[    0.052721] devtmpfs: initialized
[    0.064826] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.065854] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.067024] 26928 pages in range for non-PLT usage
[    0.067036] 518448 pages in range for PLT usage
[    0.067624] pinctrl core: initialized pinctrl subsystem
[    0.069305] DMI not present or invalid.
[    0.072920] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.075526] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.077496] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.079497] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.081841] thermal_sys: Registered thermal governor 'fair_share'
[    0.081854] thermal_sys: Registered thermal governor 'bang_bang'
[    0.082481] thermal_sys: Registered thermal governor 'step_wise'
[    0.083068] thermal_sys: Registered thermal governor 'user_space'
[    0.083673] thermal_sys: Registered thermal governor 'power_allocator'
[    0.084360] cpuidle: using governor menu
[    0.085566] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.086447] ASID allocator initialised with 65536 entries
[    0.102484] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.103974] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.105074] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.106328] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.107363] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.108585] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.109615] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.110830] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.111857] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.113080] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.117396] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.118113] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.118728] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.119407] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.120020] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.120698] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.121312] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.121985] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.123925] fbcon: Taking over console
[    0.124769] iommu: Default domain type: Passthrough
[    0.127091] usbcore: registered new interface driver usbfs
[    0.127746] usbcore: registered new interface driver hub
[    0.128315] usbcore: registered new device driver usb
[    0.129016] pps_core: LinuxPPS API ver. 1 registered
[    0.129509] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.130444] PTP clock support registered
[    0.130976] scmi_core: SCMI protocol bus registered
[    0.132695] vgaarb: loaded
[    0.133444] clocksource: Switched to clocksource arch_sys_counter
[    0.134567] VFS: Disk quotas dquot_6.6.0
[    0.134993] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.149234] NET: Registered PF_INET protocol family
[    0.150113] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.154877] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.155780] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.156576] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.157634] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.159549] TCP: Hash tables configured (established 32768 bind 32768)
[    0.160343] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.161114] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.162057] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.162689] PCI: CLS 0 bytes, default 64
[    0.163373] Unpacking initramfs...
[    0.167990] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.169943] SGI XFS with ACLs, security attributes, no debug enabled
[    0.243980] NET: Registered PF_ALG protocol family
[    0.245009] io scheduler bfq registered
[    1.446080] Freeing initrd memory: 23804K
[    1.449505] ledtrig-cpu: registered to indicate activity on CPUs
[    1.455593] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.456366] dma-pl330 fe530000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    1.460763] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.461569] dma-pl330 fe550000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    1.464187] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.468932] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 24, base_baud = 1500000) is a 16550A
[    1.470058] serial serial0: tty port ttyS1 registered
[    1.471861] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 25, base_baud = 1500000) is a 16550A
[    1.473030] printk: legacy console [ttyS2] enabled
[    1.473968] printk: legacy bootconsole [uart0] disabled
[    1.479054] loop: module loaded
[    1.495582] gadgetfs: USB Gadget filesystem, version 24 Aug 2004
[    1.496319] i2c_dev: i2c /dev entries driver
[    1.500624] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    1.548029] rk808-regulator rk808-regulator.1.auto: there is no dvs0 gpio
[    1.548717] rk808-regulator rk808-regulator.1.auto: there is no dvs1 gpio
[    1.594255] boost: Bringing 4700000uV into 5000000-5000000uV
[    1.606073] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey.2.auto/input/input0
[    1.619012] rk808-rtc rk808-rtc.3.auto: registered as rtc0
[    1.622263] rk808-rtc rk808-rtc.3.auto: setting system clock to 2025-12-26T07:44:11 UTC (1766735051)
[    1.625878] current-microamp 12500
[    1.625897]     checking 0 = 5000
[    1.626228]     checking 1 = 5750
[    1.626573]     checking 2 = 6500
[    1.626881]     checking 3 = 7250
[    1.627187]     checking 4 = 8000
[    1.627514]     checking 5 = 8750
[    1.627820]     checking 6 = 9500
[    1.628122]     checking 7 = 10250
[    1.628470]     checking 8 = 11000
[    1.628785]     checking 9 = 11750
[    1.629097]     checking 10 = 12500
[    1.629438] current-microamp 12500
[    1.629761]     checking 0 = 5000
[    1.630073]     checking 1 = 5750
[    1.630378]     checking 2 = 6500
[    1.630702]     checking 3 = 7250
[    1.631007]     checking 4 = 8000
[    1.631312]     checking 5 = 8750
[    1.631635]     checking 6 = 9500
[    1.631940]     checking 7 = 10250
[    1.632245]     checking 8 = 11000
[    1.632590]     checking 9 = 11750
[    1.632904]     checking 10 = 12500
[    1.635267] lm3630a: REG_BOOST, writing value: 35
[    1.635974] lm3630a: current_index_leda: 10
[    1.636449] lm3630a: current_index_ledb: 10
[    1.642314] lm3630a_bl 3-0036: LM3630A backlight register OK.
[    1.674945] sdhci: Secure Digital Host Controller Interface driver
[    1.675566] sdhci: Copyright(c) Pierre Ossman
[    1.675965] Synopsys Designware Multimedia Card Interface Driver
[    1.677182] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.678213] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    1.678942] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    1.679053] arm-scmi arm-scmi.7.auto: Using scmi_smc_transport
[    1.679560] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    1.679633] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 60,32 bit host data width,256 deep fifo
[    1.680086] arm-scmi arm-scmi.7.auto: SCMI max-rx-timeout: 30ms
[    1.682213] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16
[    1.683290] arm-scmi arm-scmi.7.auto: SCMI Notifications - Core Enabled.
[    1.683996] arm-scmi arm-scmi.7.auto: Malformed reply - real_sz:8  calc_sz:4  (loop_num_ret:3)
[    1.684802] arm-scmi arm-scmi.7.auto: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    1.687688] hid: raw HID events driver (C) Jiri Kosina
[    1.688286] usbcore: registered new interface driver usbhid
[    1.688823] usbhid: USB HID core driver
[    1.691835] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available
[    1.693186] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    1.693760] mmc_host mmc1: card is non-removable.
[    1.694366] NET: Registered PF_INET6 protocol family
[    1.695160] watchdog: NMI not fully supported
[    1.695607] watchdog: Hard watchdog permanently disabled
[    1.696522] Segment Routing with IPv6
[    1.696935] In-situ OAM (IOAM) with IPv6
[    1.697387] NET: Registered PF_PACKET protocol family
[    1.704230] registered taskstats version 1
[    1.712190] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    1.756084] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    1.757559] clk: Disabling unused clocks
[    1.759091] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.759823] PM: genpd: Disabling unused power domains
[    1.760662] dw-apb-uart fe660000.serial: forbid DMA for kernel console
[    1.786048] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    1.790174] Freeing unused kernel memory: 4736K
[    1.790791] Run /init as init process
[    1.791130]   with arguments:
[    1.791400]     /init
[    1.791625]     splash
[    1.791843]   with environment:
[    1.792125]     HOME=/
[    1.792338]     TERM=linux
[    1.847691] mmc_host mmc1: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[    1.917549] mmc0: new HS200 MMC card at address 0001
[    1.919467] mmcblk0: mmc0:0001 AKJ21X 115 GiB
[    1.923035]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
[    1.924960] mmcblk0boot0: mmc0:0001 AKJ21X 4.00 MiB
[    1.926462] mmcblk0boot1: mmc0:0001 AKJ21X 4.00 MiB
[    1.927845] mmcblk0rpmb: mmc0:0001 AKJ21X 4.00 MiB, chardev (249:0)
[    2.164506] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 219
[    2.168580] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[    2.381079] panel-simple panel: supply power not found, using dummy regulator
[    2.383589] panel-simple panel: Expected bpc in {6,8} but got: 4
[    2.389061] rockchip_ebc_probe start
[    2.440172] i2c_hid_of 1-0009: supply vddl not found, using dummy regulator
[    2.463720] rockchip_ebc_probe start
[    2.505596] tps65185 3-0068: detected TPS651851 r1p0
[    2.548961] rockchip_ebc_probe start
[    2.557782] rockchip-ebc fdec0000.ebc: [drm] Loaded 4-bit PVI waveform version 0x19
[    2.560308] ebc: rockchip_ebc_plane_reset
[    2.560776] [drm] Initialized rockchip-ebc 0.3.0 for fdec0000.ebc on minor 0
[    2.653316] input: w9013 2D1F:0095 Stylus as /devices/platform/fe5a0000.i2c/i2c-1/1-0009/0018:2D1F:0095.0001/input/input2
[    2.653636] input: w9013 2D1F:0095 as /devices/platform/fe5a0000.i2c/i2c-1/1-0009/0018:2D1F:0095.0001/input/input3
[    2.653944] hid-generic 0018:2D1F:0095.0001: input,hidraw0: I2C HID v1.00 Device [w9013 2D1F:0095] on 1-0009
[    2.696510] Console: switching to colour frame buffer device 234x87
[    2.830083] rockchip-ebc fdec0000.ebc: [drm] fb0: rockchip-ebcdrm frame buffer device
[    5.353444] random: crng init done
[    6.199973] EXT4-fs (mmcblk0p5): mounted filesystem ec90b0a2-921c-4d63-9f34-122769365b5d r/w with ordered data mode. Quota mode: none.
[    7.018106] systemd[1]: systemd 257.9-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
[    7.021162] systemd[1]: Detected architecture arm64.
[    7.266003] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
[    7.719002] systemd[1]: /etc/systemd/system/run_on_first_startup.service:22: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[    7.733818] systemd[1]: Queued start job for default target graphical.target.
[    7.762600] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    7.765166] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    7.767471] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    7.769199] systemd[1]: Created slice user.slice - User and Session Slice.
[    7.770124] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    7.771292] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
[    7.773084] systemd[1]: Expecting device dev-disk-by\x2dpartlabel-data.device - /dev/disk/by-partlabel/data...
[    7.774014] systemd[1]: Expecting device dev-ttyS2.device - /dev/ttyS2...
[    7.774832] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[    7.775680] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[    7.776367] systemd[1]: Reached target slices.target - Slice Units.
[    7.777018] systemd[1]: Reached target swap.target - Swaps.
[    7.780941] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[    7.782107] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    7.783309] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    7.784513] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
[    7.785330] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.786641] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.788242] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    7.789313] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    7.793702] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[    7.797654] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    7.802934] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
[    7.811908] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    7.820071] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    7.828591] systemd[1]: Mounting tmp.mount - Temporary Directory /tmp...
[    7.839942] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    7.852963] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    7.870234] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[    7.890090] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    7.898109] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    7.921195] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    7.924945] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[    7.955056] systemd[1]: Starting systemd-journald.service - Journal Service...
[    7.969000] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    7.969105] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.977016] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    7.980744] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.993122] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
[    8.006113] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    8.027581] fuse: init (API version 7.41)
[    8.031655] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[    8.033108] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[    8.037592] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock.
[    8.039746] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[    8.041302] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[    8.044110] systemd[1]: Mounted tmp.mount - Temporary Directory /tmp.
[    8.046269] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[    8.083674] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    8.085290] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[    8.091633] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    8.093847] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[    8.096318] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    8.098319] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[    8.100658] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    8.102486] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[    8.105019] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[    8.107984] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[    8.116824] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[    8.123139] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[    8.137175] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[    8.138776] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[    8.155971] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
[    8.169008] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[    8.182964] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[    8.184138] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    8.191980] systemd-journald[208]: Collecting audit messages is disabled.
[    8.201759] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
[    8.222648] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[    8.226214] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[    8.287730] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed.
[    8.301983] systemd[1]: Started systemd-journald.service - Journal Service.
[    8.428178] systemd-journald[208]: Received client request to flush runtime journal.
[    9.099648] mousedev: PS/2 mouse device common for all mice
[    9.217184] mc: Linux media interface: v0.10
[    9.238936] videodev: Linux video capture interface: v2.00
[    9.310929] panfrost fde60000.gpu: clock rate = 594000000
[    9.311489] panfrost fde60000.gpu: bus_clock rate = 500000000
[    9.360871] hantro-vpu fdea0000.video-codec: Adding to iommu group 0
[    9.372573] hantro-vpu fdea0000.video-codec: registered rockchip,rk3568-vpu-dec as /dev/video0
[    9.374657] panfrost fde60000.gpu: [drm:panfrost_devfreq_init [panfrost]] Failed to register cooling device
[    9.375648] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    9.376343] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    9.377114] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    9.378195] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    9.423682] hantro-vpu fdee0000.video-codec: Adding to iommu group 1
[    9.446251] hantro-vpu fdee0000.video-codec: registered rockchip,rk3568-vepu-enc as /dev/video1
[    9.448037] [drm] Initialized panfrost 1.2.0 for fde60000.gpu on minor 1
[    9.578798] cyttsp5 5-0024: supply vddio not found, using dummy regulator
[    9.635689] input: adc-keys as /devices/platform/adc-keys/input/input6
[    9.666293] iio iio:device2: interrupts on the falling edge or active low level
[    9.667502] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    9.671185] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.pine64,pinenote-v1.2.bin failed with error -2
[    9.749210] Bluetooth: Core ver 2.22
[    9.749724] NET: Registered PF_BLUETOOTH protocol family
[    9.750205] Bluetooth: HCI device and connection manager initialized
[    9.750834] Bluetooth: HCI socket layer initialized
[    9.751277] Bluetooth: L2CAP socket layer initialized
[    9.751782] Bluetooth: SCO socket layer initialized
[    9.798035] Bluetooth: HCI UART driver ver 2.3
[    9.798550] Bluetooth: HCI UART protocol H4 registered
[    9.803544] Bluetooth: HCI UART protocol Broadcom registered
[   10.066060] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[   10.067358] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:03:20 version 7.45.234 (4ca95bb CY) FWID 01-996384e2
[   10.083082] EXT4-fs (mmcblk0p7): mounted filesystem dbcc013f-e93f-4800-bed6-7d08301e0ba2 r/w with ordered data mode. Quota mode: none.
[   10.165199] Bluetooth: hci0: BCM: chip id 107
[   10.165941] Bluetooth: hci0: BCM: features 0x2f
[   10.167836] Bluetooth: hci0: BCM4345C0
[   10.168206] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[   10.170138] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.hcd' Patch
[   10.467879] input input5: Parameters are specified but the axis 53 is not set up
[   10.468583] input input5: Parameters are specified but the axis 54 is not set up
[   10.469238] input input5: Parameters are specified but the axis 58 is not set up
[   10.470122] input: cyttsp5 as /devices/platform/fe5e0000.i2c/i2c-5/5-0024/input/input5
[   10.933454] Bluetooth: hci0: BCM: features 0x2f
[   10.936010] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
[   10.936610] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[   11.117342] Bluetooth: MGMT ver 1.23
[   12.158186] sh[529]: using "DejaVu Sans Mono-16", pixelsize=16.67 file=/usr/share/fonts/truetype/dejavu/DejaVuSansMono.ttf
pp
Debian GNU/Linux 13 pinenote ttyS2
pinenote login:
What worked for me:
3.
(..._
Hi vlagged,
Kind regards
Sorry I am not getting notifications (mails) and did not join the forum for some time.
Did you manage to fix this?
Lately I had the same-ish problem, and fixed it with same steps: Re-creating the same wifi env as when home, ssh-ing and this time `sudo apt --fix-broken install`
Again,
was my go to solution.
I tried really hard to understand if this error was coming from an /usr/share/glib-2.0 config or dconf key, but couldn't make it work:
The mapping function given to g_settings_get_mapped() for key 'overlay-key' in schema 'org.gnome.mutter' returned FALSE when given a NULL value
  Screen size issues after update with diederik script pine-user 1 1,347 08-05-2026, 02:20 PM
Last Post: j_s
  booting is looping jabi27 2 2,521 07-27-2025, 01:36 AM
Last Post: jabi27
