bes2600 driver
#51
Hopefully, this was just an oversite and should have been changed when published to GitLab TuxThePenguin0/bes2600 repo:
* Copyright 2015-2022 BES.
* All rights reserved. All unpublished rights reserved.
* No part of this work may be used or reproduced in any form or by any
* means, or stored in a database or retrieval system, without prior written
* permission of BES.
* Use of this work is governed by a license granted by BES.
* This work contains confidential and proprietary information of
* BES. which is protected by copyright, trade secret,
* trademark and other intellectual property rights.
@u974615
Thanks for pointing this out. I found the license you mentioned in these two files.
https://gitlab.com/TuxThePenguin0/bes260...pt.h#L2-16
https://gitlab.com/TuxThePenguin0/bes260...pt.c#L1-15
Hello guys! Since we have a new bes2600 driver and also new kernel 6.6.13 and 6.8.0 (danctnix-testing) i aske me, what need to be done to get a stable, permanent MAC Address?
I have a whitelist in my router, and i want to have only 1 MAC address for my PineTab2.
it would be very helpful for the community.
(12-10-2023, 04:42 PM)tllim Wrote:
(12-09-2023, 01:02 PM)Kevin Kofler Wrote: So you have contacts to someone at BES working on the driver? Could you please talk to them about the licensing on the txrx_opt.c and txrx_opt.h files? The license header states a proprietary, GPL-incompatible license, so it ought to be fixed.
On the licensing topic, this needs to discuss with BES management team.
Any progress on this?
In addition to the license situation wrt the driver, it's also unclear if or under what conditions the firmware can be distributed.
https://gitlab.com/pine64-org/bes2600-firmware does contain the firmware files, but no license/redistribution statement.
Ideally the firmware would be submitted to https://git.kernel.org/pub/scm/linux/ker...rmware.git (f.e. via a MR on https://gitlab.com/kernel-firmware/linux-firmware/), but that should also contain a license/redistribution statement (added to WHENCE).
Otherwise it can't be distributed at least with Debian.
(03-29-2024, 08:33 AM)diederik Wrote: In addition to the license situation wrt the driver, it's also unclear if or under what conditions the firmware can be distributed.
Under Apache 2 license per BES comments
Hi, is there a repository of documentation for the BES2600 in the community? I reached out to Bestechnic but have not heard back.
I am happy to see that there is another recent push into getting the WiFi driver out of the license limbo.
https://github.com/dreemurrs-embedded/li...2/issues/3
https://salsa.debian.org/Mobian-team/dev...s2600-dkms
https://gitlab.com/pine64-org/bes2600-fi...-/issues/1
I see Mobian now has `firmware-bes2600` package. Installed it but WiFi is still cannot be activated, however it seems to be recognized already. I tried modprobe, restart, nothing helps. Is there anything else which is missing? Or is it a matter of configuration?
(10-12-2025, 12:17 AM)alpopa Wrote: I see Mobian now has `firmware-bes2600` package. Installed it but WiFi is still cannot be activated, however it seems to be recognized already. I tried modprobe, restart, nothing helps. Is there anything else which is missing? Or is it a matter of configuration?
There are threads here and guides online on how to configure and install the bes2600 driver; as far as I know it is still not officially included because of the license confusion.
