03-19-2025, 01:32 AM
Hello everyone,
first I want to phrase the question:
Is it possible to somehow reset the userpassword via setting a boot parameter in uboot to drop into a root shell (without disk encryption this should (?!) be possible in linux via the init=/bin/sh "trick"). I connected via UART and to my pinenote and tried some combinations, setting the bootcmd and others (see https://isc.sans.edu/forums/diary/Resett...ers/28564/).
now the why:
What was bugging me, since I have the pinenote for 2-3 weeks now, is that it crash-reboots at least once in a using session (no heavy actions done (?!): a bit browsing and configuring koreader, xournaling some pdfs, and stuff). I thought, this is because the system is not meant to be stable by now (as far as I understood what I read) and wasn't yet able to investigate further
Now 2 days ago I apt-upgraded via terminal and the update seemed relatively big (but it was NOT my first time running the os update). The screen froze at 55% - no reaction. I was already fearful because it happened after the downloading/unpacking part and still I powercycled it after 1-2 hours. It didn't boot anymore (it showed a dark version of the image with the squares and it said "booting ...").
I connected UART (thanks so much for delivering the dongle with it!!) and was presented a login.
Ok, what was my root password again? I've set it up a week ago and used it some times. But although I'm 98% sure that I got it right, I was not able to log in.
Ok, I created another user with sudo permissions and because of the many reboots of the pinenote I had to put it in very frequently, so I'm 99,999% sure that I have it right (still there was a slight uncertainty, because the password is somehow bound to the layout of the on-screen-keyboard) - NO, not able to login.
Ok, what was the password of ther originals "user" ... yeah, I'm able to log in ... BUT ... as I created another user I removed sudo group from "user" -.-
Now I'm confused even more - I can see that the user I created really exists in /etc/passwd ... so once again my reality is questioned - why wasn't I able to login?
Did I tried to much and some new PAM restriction is active by default in Trixie? Seems not so. But I remembered the workaround of dropping to a root shell in grub, maybe/hopefully this also works here? But I'm not very proficient with uboot and UART yet.
Alternatively: can I copy the bootmenu file from the pine, change it and put it back?
Maybe there is an even easier option I didn't think of yet, before I have to flash it(?!)
now the why:
Password reset via u-boot (init=/bin/sh) possible?
