Hello
The bottom right corner of the touchscreen doesn't respond, I cannot enter the password. I highly suspect an hardware defect, I had the same trouble on my very first Pinephone.
Could it be caused by a software problem?
Is there a workaround in the meantime so that I can login? For example, can I force the Pinephone to enable the screen rotation very early? Can I use the dock?
Does someone have some experience on replacing the touchscreen? I will probably do that and if it works on my current Pinephone, I will do the same on my previous Pinephone.
P.S: I can login by using the dock but half of the user interface doesn't appear on the screen and the keyboard starts working correctly only after entering the password. Note that I use full disk encryption.
Impossible to login, bottom right corner of the touchscreen not responding
I'm so happy, it works much better now and I won't hesitate to repair my Pinephone by myself from now on
