PineTab2 corrupted EMMC
Today i got my PineTab2 delivered. Unfortunately it seems, that the emmc is somehow corrupted.
The Tablet won't turn on.
I created MicroSD Card with factory Image from here:
https://echo.danctnix.org:7269/danctnix-...527.img.xz
When i turn it on with the Debug Adapter booting from Micro-SD Card it boots from MicroSD Card.
When i choose Flash OS to emmc card, it begins to write, but it throws some errors, about mmc init (See log)
When the writing is about 60% it shows - Flashing Successfull. When i switch off the tablet, but it still wont turn on.
(11-16-2023, 06:01 PM)explit Wrote: Today i got my PineTab2 delivered. Unfortunately it seems, that the emmc is somehow corrupted.
Looks like Flash process premature quite at 60% and fro sure the code in eMMC still not complete programmed. Please reflash again and hopefully this time 100% completed.
After 26 unsuccessful attempts to reflash the emmc - it worked.
I don't know what changed, battery was charged over 80%.
Suddenly there were no more mmc initialization errors and the process could go over 100% successfully. Thread can be closed. Thanks all for support and help!
How did you get to the PineTab2 Factory Tool?  I'm looking to re-install Arch on my PineTab 2 using the UART adapter, but it just boots to login screen.  I'm not sure how to get to this factory tool.  Thanks!
Disregard.  Big Grin
My reflashing of the emmc only took ~8 attempts. Failing progress was to slowly get to 60% and then ended with no error. Not sure what I did differently but power was plugged into UART board and battery was at 100% at time of successful re-flashing.
I am experiencing this same issue. I am on attempt #3, but cycling through to try to get it to work.
Does anyone have any updates or additional helpful tips for resolving this?
Video Pinetab2 camera drivers cringeops 13 11,948 07-18-2026, 12:51 PM
  Is Danctnix about to get cameras on Pinetab2 biketool 0 1,216 12-11-2025, 06:19 AM
  Danctnix USB GPS for Pinetab2 biketool 0 997 11-28-2025, 06:09 AM
  auto-owning the SD card in DanctNIX (Pinetab2) biketool 1 1,486 11-25-2025, 04:16 AM
Sad USB Gadget on PineTab2 Tronar 0 4,137 09-26-2025, 12:42 PM
Last Post: Tronar
  pinetab2 danctnix broken during upgrade - shell error acruhl 6 12,509 07-23-2025, 06:27 PM
Last Post: acruhl
  SailfishOS on PT2: flashing the emmc defactofactotum 2 4,050 09-18-2024, 02:44 AM
Last Post: schuster2
  OS Options for Pinetab2 Evergreen 2 3,888 09-07-2024, 07:35 AM
Last Post: moobythegoldensock
  Cannot get into Pinetab2 joespodie 1 2,669 09-02-2024, 11:52 AM
  eMMC backup - pinetab2 pinetar.gz 0 2,376 01-07-2024, 09:08 PM
Last Post: pinetar.gz
