This question came up on the kickstarter comments page, if anyone could give a brief (or detailed) explanation of what the Euler Bus is and does, that would be great.
What exactly is a Euler Bus?
01-24-2016, 04:23 PM
agreed !!
By. Zoidiano0!
Installed: LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5 Java 8 arm by oracle Netbeans 8.1 chromium (uses way toooo much Ram) Pine64 Head Unit Project.!
01-24-2016, 05:50 PM
(01-24-2016, 03:42 PM)SkairkrohBule Wrote: This question came up on the kickstarter comments page, if anyone could give a brief (or detailed) explanation of what the Euler Bus is and does, that would be great. Euler bus consider as an extension to Pi bus, it has more UART ports, SPI ports, I2S ports, AV ports and more GPIOs. It also has speaker port and you can connect a small speaker to the port. (01-24-2016, 05:50 PM)tllim Wrote:(01-24-2016, 03:42 PM)SkairkrohBule Wrote: This question came up on the kickstarter comments page, if anyone could give a brief (or detailed) explanation of what the Euler Bus is and does, that would be great. Thanks to you, tllim. So the Euler Bus is an extended Input Output interface that allows for further connections of various types from external devices, such as speakers. To clarify those port types (please correct if wrong): UART = Universal Asynchronous Receiver/Transmitter (https://en.m.wikipedia.org/wiki/Universa...ransmitter) SPI = Serial Peripheral Interface (https://en.m.wikipedia.org/wiki/Serial_P...erface_Bus) I²S= Integrated Interchip Sound (https://en.m.wikipedia.org/wiki/I%C2%B2S) AV = Audio/Video (https://en.m.wikipedia.org/wiki/Audio_an...connectors) GPIO = General Purpose Input/Output (https://en.m.wikipedia.org/wiki/General-...put/output)
01-25-2016, 07:38 AM
Wait a minute so this board had composite video in?
It would be great
By. Zoidiano0!
01-27-2016, 02:13 AM
I²C (Inter-Integrated Circuit) https://en.wikipedia.org/wiki/I%C2%B2C
01-27-2016, 03:12 AM
(01-27-2016, 02:13 AM)DeepBlu Wrote: To clarify those port types (please correct if wrong): Euler Bus has I²S ports rather than I²C. At least that's what the pin-out seems to indicate...there are perhaps some I²C ports on the Pi-2 interface...
01-27-2016, 05:00 AM
(01-27-2016, 03:12 AM)SkairkrohBule Wrote:(01-27-2016, 02:13 AM)DeepBlu Wrote: To clarify those port types (please correct if wrong): Yes, there is an I2C bus at the Pi-2 interface pin 3 and 5. an I2C bus can be used for many DIY projects e.g. A/D or D/A converters etc. ets.
05-06-2016, 04:51 PM
On the EULER pin out, are the 3.3v pins (1, 17) inputs or outputs?
Thank you. |
| +LTS/SOPINE +PINEBOOK configuring Euler Bus pin generate interrupt | RANJITT76 | 0 | 3,941 |
01-10-2019, 02:45 AM Last Post: RANJITT76 |
| connect lipo battery to euler bus | jodybrown99 | 19 | 41,517 |
09-14-2016, 11:51 PM Last Post: pfeerick |
| Mapping Euler bus DC in and 5v DC out pins | g_t_j | 8 | 17,345 |
07-02-2016, 09:30 PM Last Post: tllim |
| Euler Bus | hrh1818 | 4 | 18,141 |
01-29-2016, 01:56 PM Last Post: tllim |
