PinePhonePro turns on when connecting usb charging cable
  Is there a way to make it not to switch on when connecting the usb charging cable?
thanks
(10-04-2023, 07:42 AM)xt0 Wrote: Hi,
thanks
 i think it's a feature
 the same on pinephone
 ezik
thanks
 ezik
@ezik, thanks for the answer... so what your saying is the phone can be charged only when it is on...? If that's so, is there any configuration on Manjaro that alters this behaviour?
thanks
 ezik
 you can switch it off when the cable is connected and it keeps charging
 ezik
thanks
 ezik
 ezik
Hi, my PinePhonePro reboots instead of keeping charging in shutdown state.
this is related, https://xnux.eu/rk2aw/ .
small computers have bad habit to turn on when power cable is plugged, but generally speaking it shouldn't turn on after turning off. above software may fix these issues partially.
  USB charging is unreliable lightwo 0 2,336 05-17-2024, 04:29 AM
Last Post: lightwo
  PinePhone only turns on sometimes zvavybir 1 3,607 03-27-2024, 12:19 PM
Last Post: zvavybir
  New out of box phone, vibrates and solid red light on charging StuckInTheCloud 1 3,854 03-24-2023, 03:12 PM
Last Post: fxc
Question Battery not charging when run down to 0. iwm 2 4,776 02-08-2022, 10:45 AM
Last Post: mburns
  charging indicator nristen 16 22,921 02-03-2022, 04:36 PM
Last Post: phelion
  USB to PC connection not charging PPP tckosvic 0 2,494 02-01-2022, 05:40 PM
Last Post: tckosvic
