SATA keeps crashing
I had several problems with my harddrives during burn in test. I believe I made it more stable by using an overpowered beQuiet ATX power supply.
But still after about 10 hours of burn in, one of the drives disappeared from system.
is there anything I could do about it, or should I try a different SATA adapter?
It's a ASM1166 based one.
thanks
JPT
kernel: [20815.037460] ata31.00: exception Emask 0x11 SAct 0xffffffff SErr 0x0 action 0x6 frozen
kernel: [20815.037488] ata31.00: irq_stat 0x48000008, interface fatal error
kernel: [20815.037498] ata31.00: failed command: WRITE FPDMA QUEUED
kernel: [20815.037504] ata31.00: cmd 61/00:00:00:b4:68/04:00:06:00:00/40 tag 0 ncq dma 524288 out
kernel: [20815.037504]          res 40/00:90:00:78:68/00:00:06:00:00/40 Emask 0x10 (ATA bus error)
kernel: [20815.037728] ata31.00: status: { DRDY }
(repeated  ~30 times)
kernel: [20815.038403] ata31.00: failed command: WRITE FPDMA QUEUED
kernel: [20815.038407] ata31.00: cmd 61/00:f8:00:94:68/04:00:06:00:00/40 tag 31 ncq dma 524288 out
kernel: [20815.038407]          res 40/00:90:00:78:68/00:00:06:00:00/40 Emask 0x10 (ATA bus error)
kernel: [20815.038425] ata31.00: status: { DRDY }
kernel: [20815.038438] ata31: hard resetting link
kernel: [20815.351579] ata31: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
kernel: [20815.351797] ata31.00: revalidation failed (errno=-2)
kernel: [20820.373226] ata31: hard resetting link
kernel: [20820.687580] ata31: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
kernel: [20820.687821] ata31.00: revalidation failed (errno=-2)
kernel: [20825.749275] ata31: hard resetting link
kernel: [20826.063641] ata31: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
kernel: [20826.063877] ata31.00: revalidation failed (errno=-2)
kernel: [20826.063884] ata31.00: disable device
kernel: [20826.064897] ata31: EH complete
kernel: [20826.065122] sd 30:0:0:0: [sdb] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=11s
kernel: [20826.065137] sd 30:0:0:0: [sdb] tag#16 CDB: opcode=0x2a 2a 00 06 68 b4 00 00 04 00 00
kernel: [20826.065145] I/O error, dev sdb, sector 107525120 op 0x1:(WRITE) flags 0x800 phys_seg 128 prio class 2
kernel: [20826.065414] sd 30:0:0:0: [sdb] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [20826.065423] sd 30:0:0:0: [sdb] tag#16 CDB: opcode=0x2a 2a 00 02 c4 61 00 00 03 00 00
kernel: [20826.065427] I/O error, dev sdb, sector 46424320 op 0x1:(WRITE) flags 0x0 phys_seg 96 prio class 2
(repeated ~5 times)
kernel: [20826.066623] sd 30:0:0:0: [sdb] tag#20 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=11s
kernel: [20826.066634] sd 30:0:0:0: [sdb] tag#20 CDB: opcode=0x2a 2a 00 06 68 c6 80 00 05 40 00
kernel: [20826.066640] I/O error, dev sdb, sector 107529856 op 0x1:(WRITE) flags 0x4800 phys_seg 168 prio class 2
kernel: [20826.069242] md: super_written gets error=-5
kernel: [20826.069252] md/raid:md127: Disk failure on sdb1, disabling device.
kernel: [20826.069258] md/raid:md127: Operation continuing on 2 devices.
udisksd[1114]: Error performing housekeeping for drive /org/freedesktop/UDisks2/drives/ST31500341AS_9VS4VMED: Error updating SMART data: Error sending ATA command CHECK POWER MODE: Unexpected sense data returned:#0120000: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................#0120010: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................#012 (g-io-error-quark, 0)
kernel: [21040.731415] scsi_io_completion_action: 38 callbacks suppressed
kernel: [21040.731431] sd 30:0:0:0: [sdb] tag#20 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [21040.731443] sd 30:0:0:0: [sdb] tag#20 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31257]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
systemd[1]: Starting sysstat-collect.service - system activity accounting tool...
systemd[1]: sysstat-collect.service: Deactivated successfully.
systemd[1]: Finished sysstat-collect.service - system activity accounting tool.
CRON[31271]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
kernel: [21640.672280] sd 30:0:0:0: [sdb] tag#21 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [21640.672297] sd 30:0:0:0: [sdb] tag#21 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31286]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
CRON[31287]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
CRON[31300]: (root) CMD (cd / && run-parts --report /etc/cron.hourly)
kernel: [22240.621574] sd 30:0:0:0: [sdb] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [22240.621590] sd 30:0:0:0: [sdb] tag#0 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31319]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
kernel: [22840.638787] sd 30:0:0:0: [sdb] tag#22 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [22840.638804] sd 30:0:0:0: [sdb] tag#22 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31329]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
CRON[31344]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
kernel: [23440.723283] sd 30:0:0:0: [sdb] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [23440.723303] sd 30:0:0:0: [sdb] tag#1 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31360]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
CRON[31361]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
kernel: [24040.628704] sd 30:0:0:0: [sdb] tag#23 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [24040.628722] sd 30:0:0:0: [sdb] tag#23 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31384]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
kernel: [24640.892353] sd 30:0:0:0: [sdb] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [24640.892370] sd 30:0:0:0: [sdb] tag#2 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31391]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
CRON[31406]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
kernel: [25240.596445] sd 30:0:0:0: [sdb] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [25240.596479] sd 30:0:0:0: [sdb] tag#24 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31423]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
CRON[31422]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
CRON[31435]: (root) CMD (cd / && run-parts --report /etc/cron.hourly)
kernel: [25840.681021] sd 30:0:0:0: [sdb] tag#25 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [25840.681037] sd 30:0:0:0: [sdb] tag#25 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31452]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
kernel: [26440.930199] sd 30:0:0:0: [sdb] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [26440.930220] sd 30:0:0:0: [sdb] tag#26 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31461]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
CRON[31473]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
kernel: [27040.733170] sd 30:0:0:0: [sdb] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [27040.733186] sd 30:0:0:0: [sdb] tag#3 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31491]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
CRON[31492]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
kernel: [27640.759305] sd 30:0:0:0: [sdb] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [27640.759322] sd 30:0:0:0: [sdb] tag#27 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31513]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
kernel: [28240.801000] sd 30:0:0:0: [sdb] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
kernel: [28240.801015] sd 30:0:0:0: [sdb] tag#4 CDB: opcode=0x85 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
CRON[31522]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
CRON[31537]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
(09-21-2023, 03:23 AM)JPT223 Wrote: Hi,
thanks
JPT
(repeated ~5 times)
May be the ASm1166 chip getting too hot, please a heatsink may improve the stability.
  Which SATA card should I use my NAS server RAID5 Louysa 3 5,663 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA hotplug not working? JPT223 0 3,199 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 5,390 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 49,317 12-18-2022, 06:25 PM
Last Post: heyghoge
  Existings disks and using a StarTech SATA Controller jkugler 1 4,677 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
  Rockpro64 Sata Card kills itself jerry110 33 77,022 10-20-2021, 04:36 AM
Last Post: fieni
  Right direction SATA card corax 2 6,567 09-15-2021, 12:46 PM
Last Post: corax
  Mellanox 10Gbit Connect-x 3en Crashing cmosfxx 0 3,299 02-07-2021, 11:26 PM
Last Post: cmosfxx
  Won't boot with SATA card rjzak 4 10,473 01-09-2021, 05:56 PM
Last Post: kuleszdl
  SATA issues machina 25 58,645 10-16-2020, 12:16 PM
Last Post: lrb
