Acrylic Post and Bolts Info
Answer for Anthony Cunningham
I have been meaning to give you an answer to your Acrylic Case mounting bolts question posed in KickStarter comments.
The coarse thread measures 7.8mm diameter across thread, 1.15mm thread pitch, there is 14mm of screw thread.
The supplied flat head is 4mm thick, 12.23mm diameter with no screwdriver slot or hole - just screwed in by hand.
The spacer/tubes only have a few mm of thread then open out to the full width and depth of the tube (less a few mm at the other end) so no limit to length of screw.
Tube outside diameter is 12mm.
Cheers ... Neil
(06-09-2016, 02:40 PM)neilman Wrote: Answer for Anthony Cunningham
Cheers ... Neil
Thanks for that. I ordered some M8 grub screws from eBay (30mm length) and used them to stack the cases one on top of the other. The ones I ordered had a hex socket hole at one end which came in handy when getting the screws through the holes in the case. (Although the screws fitted to posts perfectly they were quite stiff when going through the case parts).
Thanks for this info, I can confirm they are indeed M8 I'm using these Stainless Steel M8x30mm Hex Socket Head Set Grub Screws
https://www.amazon.com/gp/product/B01ARS...UTF8&psc=1
Backer #17,640
  Are the Pine64 Acrylic Open Enclosures Stackable? abhinava 5 15,495 09-17-2020, 06:41 AM
Last Post: dabou
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 21,811 10-24-2016, 08:18 AM
Last Post: killor
Video Acrylic enclosure for PINE A64 killor 71 143,670 08-12-2016, 06:53 AM
Last Post: killor
  Posts for Acrylic Case not provided Rob 1 5,467 07-16-2016, 06:04 PM
  Broken standoff on acrylic case RonRN18 4 10,230 07-14-2016, 02:54 PM
Last Post: tomarneson
  Simple Acrylic Enclosure dr4x0n 1 4,863 06-21-2016, 09:49 AM
Last Post: MarkHaysHarris777
  PineA64 Cooling Fan and Initial Thoughts Post MarkHaysHarris777 4 10,501 06-17-2016, 06:49 AM
  Acrylic Case Posts tjctjc 4 10,543 06-12-2016, 09:32 AM
Last Post: tjctjc
  Acrylic enclosure mFinnholm 4 10,226 05-24-2016, 12:17 PM
Last Post: mFinnholm
  PINE64 Acrylic Open Enclosure jmc 9 21,179 04-10-2016, 06:15 PM
Last Post: Coterabeth
