[Megapixels] Flash strobe, pictures viewer and MPCamera error 22
Hi all,
I'm in bookworm mobian and do all latest available updates/upgrades on repo.
I have megapixels with 1.6.0-1+b1 version.
As suggest, i have installed necessary packages "dcraw" and "imagemagick".
In log, flash strobe is not openned.
Failed to open /sys/class/leds/white:flash/flash_strobe
And when i clicked on picture small icon to launch the picture viewer, it returned to me this error.
display-im6.q16: unable to open X server `' @ error/display.c/DisplayImageCommand/412.
Moreover, some camera log give error 22 as described follow.
MPCamera: VIDIOC_SUBDEV_S_FRAME_INTERVAL error 22, Argument invalide MPCamera: VIDIOC_QBUF error 22, Argument invalide
Thanks a lot for your feedback.
All log megapixels from term are here.
megapixels Found config file at /usr/share/megapixels/config/pine64,pinephone-1.2.ini Adding camera rear from config Adding camera front from config Failed to open /sys/class/leds/white:flash/flash_strobe MPCamera: VIDIOC_SUBDEV_S_FRAME_INTERVAL error 22, Argument invalide Initialized OpenGL ES 2.0 TIFF version 20221213 Writing frame to /tmp/megapixels.SXpdil/0.dng TIFF version 20221213 Writing frame to /tmp/megapixels.SXpdil/1.dng TIFF version 20221213 Writing frame to /tmp/megapixels.SXpdil/2.dng Making thumbnail TIFF version 20221213 Writing frame to /tmp/megapixels.SXpdil/3.dng Post process /tmp/megapixels.SXpdil to /home/home/Images/IMG20230317080048.ext (save-dng 1) MPCamera: VIDIOC_SUBDEV_S_FRAME_INTERVAL error 22, Argument invalide MPCamera: VIDIOC_QBUF error 22, Argument invalide display-im6.q16: unable to open X server `' @ error/display.c/DisplayImageCommand/412. display-im6.q16: unable to open X server `' @ error/display.c/DisplayImageCommand/412.
I had this error with megapixels as well.
Some searching led me to this thread, https://forum.pine64.org/showthread.php?...OC_REQBUFS
And I did have the mesa 22.3.3 packages that don't work correctly.
I downgraded, to the 22.3.2 packages and was able to take pictures with megapixels without it crashing.
Using the list of packages from the other thread I used this list of curl commands to download replacement packages from snapshot.debian.org, I installed those and megapixels worked. (Also some other graphical glitches got better as well)
curl -L -O https://snapshot.debian.org/archive/debian/20230112T090754Z/pool/main/m/mesa/libgbm1_22.3.2-1_arm64.deb curl -L -O https://snapshot.debian.org/archive/debian/20230112T090754Z/pool/main/m/mesa/libegl-mesa0_22.3.2-1_arm64.deb curl -L -O https://snapshot.debian.org/archive/debian/20230112T090754Z/pool/main/m/mesa/mesa-va-drivers_22.3.2-1_arm64.deb curl -L -O https://snapshot.debian.org/archive/debian/20230112T090754Z/pool/main/m/mesa/libglapi-mesa_22.3.2-1_arm64.deb curl -L -O https://snapshot.debian.org/archive/debian/20230112T090754Z/pool/main/m/mesa/libglx-mesa0_22.3.2-1_arm64.deb curl -L -O https://snapshot.debian.org/archive/debian/20230112T090754Z/pool/main/m/mesa/libgl1-mesa-dri_22.3.2-1_arm64.deb curl -L -O https://snapshot.debian.org/archive/debian/20230112T090754Z/pool/main/m/mesa/mesa-vdpau-drivers_22.3.2-1_arm64.deb
I have installed all dependencies mesa in 22.3.2-1 version but maybe with apt reinstall libglapi-mesa_22.3.2-1.
I will check this, thanks a lot
Be appear, it's better with this package version 20230112T090754Z
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 5,128 11-16-2023, 05:03 AM
Last Post: DrYak
Photo Can no longer take pictures, /dev/video* not recognized as video devices 64_Tesseract 0 2,062 01-26-2023, 10:19 AM
Last Post: 64_Tesseract
  Error Vandal187UM 0 2,381 03-13-2021, 11:06 PM
Last Post: Vandal187UM
  New motherboard - ANX firmware won't flash. --- 17 27,031 12-26-2020, 01:53 PM
Last Post: p1x3l3d
  eMMC won't flash RodMyers 3 8,783 09-12-2020, 06:38 PM
Last Post: SwordfishII
  Avoiding modem flash-memory corruption? msquared 6 12,724 06-16-2020, 06:05 AM
Last Post: ---
  Error in the spec of the pinephone someGermanGuy 1 5,205 02-18-2020, 03:29 PM
Last Post: dukla2000
  Camera/Flash Protector kuro 0 3,397 01-16-2020, 09:47 AM
Last Post: kuro
