can the pinephone be operated with a stylus?
Question
i think it might be nice to operate the pinephone with a stylus, especially if you scale the apps down.
is that supported? what type of stylus would i need to buy to just operate the touch screen?
thanks!
Depends on the stylus. The touchscreen is capacitive so any stylus designed to work on capacitive touchscreens should work. That usually means having a sufficiently large conductive tip though, so not great for precision. It's not like the active Wacom type stylus, or a resistive touchscreen like we had on the OpenMoko or Psion.
thanks! then i can start looking for a capacitive compatible stylus and see if i like that
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,940 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,562 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 11,732 06-03-2025, 04:19 PM
Last Post: j_s
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,784 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 24,787 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,717 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,627 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,436 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 5,321 06-29-2024, 09:36 PM
  Was someone able to use the Pinephone keyboard & an usb mouse at the same? Peter Gamma 4 13,090 06-26-2024, 07:11 AM
Last Post: dachalife
