V2 with V1 label?
Question
I just noticed that my new V2 has the same label on its housing as the V1.
Pics in the wiki show the V2 label has the expanded voltage and power range:
[Image: Pinecilv2-2.jpg]
But mine still shows the same as the V1:
[Image: pinecil_v2_case.jpg]
Bought from the Pine64 store (Order #247671) so I'm confident it's genuine and probably just the wrong case, but is there any way to check the hardware version without disassembling (lazy)?
Used the V2 Authenticity Checker and it says that it is V2 so I guess that's good enough.
(10-04-2022, 03:42 PM)surt Wrote: Used the V2 Authenticity Checker and it says that it is V2 so I guess that's good enough.
you should send  Email to  Pine store support.  it is supposed to come with outter  shell that says  18W - 88W on it.  let them know   Authenticity worked but shell is wrong.   We also have a channel  live  volunteers    in Pine64 Discord  under Pinecil.
I ordered a second one and ended up receiving two by mistake (correct case in the one I checked). Emailed the store and they said to keep it if no one's missing one within a few weeks, so I'll probably get the right case plus the rest as a bonus.
